Iterative implementation of services for the automatic evaluation of matching tools - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Contrat/Projet) Année : 2011
The implementation of the automatic services for evaluating matching tools follows an iterative model. The aim is to provide a way for continuously analysing and improving these services. In this deliverable, we report the first iteration of this process, i.e., current implementation status of the services. In this first iteration, we have extended our previous implementation in order to migrate our own services to the SEALS components, which have been finished since the end of the first evaluation campaign.
seals-125.pdf (1.42 Mo) Télécharger le fichier
hal-00793436 , version 1 (22-02-2013)
  • HAL Id : hal-00793436 , version 1
Cassia Trojahn dos Santos, Christian Meilicke, Jérôme Euzenat. Iterative implementation of services for the automatic evaluation of matching tools. [Contract] 2011, pp.21. ⟨hal-00793436⟩
153 Consultations
152 Téléchargements
