An Enhanced Parareal Algorithm for Partitioned Parabolic-Hyperbolic Coupling - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
We present a parallel time‐marching scheme for coupled parabolic‐hyperbolic problems, as a prototype of fluid‐structure interaction problems involving a linear structure and a viscous fluid. No linearity assumption is made on the parabolic side. The classical Parareal scheme is applied to the parabolic part, while the modified algorithm proposed by Farhat et al. [1] is applied to the hyperbolic part. This hybrid Parareal treatment relies on the partitioned formulation of the coupled propagator. Numerical evidence shows that the resulting scheme is stable for a wide range of physical and discretization parameters.
Fichier non déposé
hal-00793490 , version 1 (22-02-2013)
Franz Chouly, Miguel Angel Fernández. An Enhanced Parareal Algorithm for Partitioned Parabolic-Hyperbolic Coupling. International Conference on Numerical Analysis and Applied Mathematics 2009, Sep 2009, Rethymno, Crete, Greece. pp.1517-1520, ⟨10.1063/1.3241387⟩. ⟨hal-00793490⟩
74 Consultations
0 Téléchargements
