HOCL Installation Guide
HOCL (Higher Order Chemical Language) is a chemical programming language. Computations can be seen as chemical reactions which are controlled by a set of chemical rules. We have an HOCL compiler developed in JAVA. This manual aims at presenting how to install and then use this compiler to compile and execute the HOCL programs.
