New interface
Conference papers
Selecting an efficient OO integration testing strategy: An experimental comparison of actual strategies
Vu Le Hanh 1 Akif Kamel 1 Yves Le Traon 1 Jean-Marc Jézéquel 1
1 TRISKELL - Reliable and efficient component based software engineering
IRISA - Institut de Recherche en Informatique et Systèmes Aléatoires, Inria Rennes – Bretagne Atlantique
Abstract : The normalization of semi-formal modeling methods, such as the UML, leads to re-visit the problem of early 00 integration test planning. Integration is often conducted under some incremental steps. Integration test planning aims at ordering the components to be integrated and tested in relationships with the already tested part of the system. This paper presents a modeling of the test integration problem from a UML design, then details existing integration strategies and proposes two integration strategies: a deterministic one called Triskell and an original semi-random one, based on genetic algorithms called Genetic. Strategies are compared in detail (algorithmic cost and optimization choices) and a large part of the paper is dedicated to an experimental comparison of each strategy on 6 real-world case studies of various complexities (from a "small" telecommunication software to the Swing Java library). Results show that a good modeling of this optimization problem associated with well-chosen algorithms induce a significant gain in terms of testing effort and duration.
Document type :
Conference papers
Complete list of metadata
Cited literature [16 references]  Display  Hide  Download
https://hal.inria.fr/hal-00794533
Contributor : Jean-Marc Jézéquel Connect in order to contact the contributor
Submitted on : Tuesday, February 26, 2013 - 10:08:18 AM
Last modification on : Friday, February 4, 2022 - 3:25:00 AM
Long-term archiving on: : Sunday, April 2, 2017 - 5:11:57 AM
File
Hanh01a.pdf
Identifiers
  • HAL Id : hal-00794533, version 1
Citation
Vu Le Hanh, Akif Kamel, Yves Le Traon, Jean-Marc Jézéquel. Selecting an efficient OO integration testing strategy: An experimental comparison of actual strategies. Proceedings of ECOOP2001, Jun 2001, Budapest, Hungary. ⟨hal-00794533⟩
Share
Metrics
Record views
140
Files downloads
554
