New interface
Conference papers
System test synthesis from UML models of distributed software
Simon Pickin 1 Claude Jard 1 Yves Le Traon 1 Thierry Jéron 1 Jean-Marc Jézéquel 1 Alain Le Guennec 1
1 TRISKELL - Reliable and efficient component based software engineering
IRISA - Institut de Recherche en Informatique et Systèmes Aléatoires, Inria Rennes – Bretagne Atlantique
Abstract : The object-oriented software development process is increasingly used for the construction of both centralised and distributed systems. As yet, however, formal V&V techniques have not found much use in the object-oriented context, in spite of the fact that some are now mature enough to be exercised in real world applications. In this paper, we investigate the use of formal validation in a UML-based development process. We present a method and a tool for automated synthesis of test cases from generic test scenarios and a design model of the application, remaining entirely within the UML framework. The underlying "on the fly" test synthesis algorithms are based on the input/output labelled transition formalism, which is particularly appropriate for modelling applications which may involve asynchronous communication. We illustrate the system test synthesis process using an Air Traffic Control software case study.
Document type :
Conference papers
Complete list of metadata
Cited literature [10 references]  Display  Hide  Download
https://hal.inria.fr/hal-00794606
Contributor : Jean-Marc Jézéquel Connect in order to contact the contributor
Submitted on : Tuesday, February 26, 2013 - 11:10:17 AM
Last modification on : Friday, February 4, 2022 - 3:24:34 AM
Long-term archiving on: : Sunday, April 2, 2017 - 5:14:14 AM
File
Pickin02a.pdf
Identifiers
  • HAL Id : hal-00794606, version 1
Citation
Simon Pickin, Claude Jard, Yves Le Traon, Thierry Jéron, Jean-Marc Jézéquel, et al.. System test synthesis from UML models of distributed software. Formal Techniques for Networked and Distributed Systems - FORTE 2002, Nov 2002, Houston, United States. ⟨hal-00794606⟩
Share
Metrics
Record views
228
Files downloads
111
