Computational geometry-based scale-space and modal image decomposition: Application to light video-microscopy imaging - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
In this paper a framework for defining scale-spaces, based on the computational geometry concepts of α-shapes, is proposed. In this approach, objects (curves or surfaces) of increasing convexity are com- puted by selective sub-sampling, from the original shape to its convex hull. The relationships with the Empirical Mode Decomposition (EMD), the curvature motion-based scale-space and some operators from math- ematical morphology, are studied. Finally, we address the problem of additive image/signal decomposition in fluorescence video-microscopy. An image sequence is mainly considered as a collection of 1D temporal signals, each pixel being associated with its temporal intensity variation.
2009_ssvm_chessel.pdf (327.16 Ko) Télécharger le fichier
hal-00794884 , version 1 (26-02-2013)
  • HAL Id : hal-00794884 , version 1
Anatole Chessel, Bertrand Cinquin, Sabine Bardin, Jean Salamero, Charles Kervrann. Computational geometry-based scale-space and modal image decomposition: Application to light video-microscopy imaging. Internationale Conference on Scale Space and Variational Methods, Jun 2009, Voss, Norway. pp.770-781. ⟨hal-00794884⟩
252 Consultations
104 Téléchargements
