Towards metamorphic semantic models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Ontological model transformation inside the OWL formalism, preserving the intended meaning across modelling styles, could support diverse kinds of semantic web applications. Three use cases are mentioned, which could share a single ontology transformation service based on a transformation pattern library. We discuss the ontology matching use case in more detail and illustrate on a simple example.
Autre [cs.OH]
Fichier non déposé
hal-00794901 , version 1 (26-02-2013)
  • HAL Id : hal-00794901 , version 1
Ondrej Sváb-Zamazal, Vojtech Svátek, Jérôme David, François Scharffe. Towards metamorphic semantic models. Proc. 6th european conference on semantic web (ESWC), Jun 2009, Heraklion, Greece. No pagination. ⟨hal-00794901⟩
77 Consultations
0 Téléchargements
