Results of the Ontology Alignment Evaluation Initiative 2009 - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Pavel Shvaiko
  • Fonction : Auteur
  • PersonId : 1323368
Ontology matching consists of finding correspondences between on- tology entities. OAEI campaigns aim at comparing ontology matching systems on precisely defined test cases. Test cases can use ontologies of different nature (from expressive OWL ontologies to simple directories) and use different modal- ities, e.g., blind evaluation, open evaluation, consensus. OAEI-2009 builds over previous campaigns by having 5 tracks with 11 test cases followed by 16 partici- pants. This paper is an overall presentation of the OAEI 2009 campaign.
oaei2009.pdf (704.24 Ko) Télécharger le fichier
hal-00794918 , version 1 (14-05-2013)
  • HAL Id : hal-00794918 , version 1
Jérôme Euzenat, Alfio Ferrara, Laura Hollink, Antoine Isaac, Cliff Joslyn, et al.. Results of the Ontology Alignment Evaluation Initiative 2009. Proc. 4th ISWC workshop on ontology matching (OM), Oct 2009, Chantilly, United States. pp.73-126. ⟨hal-00794918⟩
830 Consultations
430 Téléchargements
