New interface
Conference papers
An MDA approach to tame component based software development
Jean-Marc Jézéquel 1 Olivier Defour 1 Noël Plouzeau 1
1 TRISKELL - Reliable and efficient component based software engineering
IRISA - Institut de Recherche en Informatique et Systèmes Aléatoires, Inria Rennes – Bretagne Atlantique
Abstract : The aim of this paper is to show how the Model Driven Architecture (MDA) can be used in relation with component based software engineer- ing. A software component only exhibits its provided or required interfaces, hence defining basic contracts between components allowing one to properly wire them. These contractually specified interfaces should go well beyond mere syntactic aspects: they should also involve functional, synchronization and Quality of Service (QoS) aspects. In large, mission-critical component based systems, it is also particularly important to be able to explicitly relate the QoS contracts attached to provided interfaces with the QoS contracts ob- tained from required interfaces. We thus introduce a QoS contract model (called QoSCL for QoS Constraint Language), allowing QoS contracts andtheir dependencies to be modeled in a UML2.0 modeling environment.
Document type :
Conference papers
Complete list of metadata
Cited literature [24 references]  Display  Hide  Download
https://hal.inria.fr/hal-00795036
Contributor : Jean-Marc Jézéquel Connect in order to contact the contributor
Submitted on : Wednesday, February 27, 2013 - 3:32:36 PM
Last modification on : Friday, February 4, 2022 - 3:25:02 AM
Long-term archiving on: : Sunday, April 2, 2017 - 5:56:18 AM
File
Jezequel04d.pdf
Identifiers
  • HAL Id : hal-00795036, version 1
Citation
Jean-Marc Jézéquel, Olivier Defour, Noël Plouzeau. An MDA approach to tame component based software development. Post Proceedings of Formal Methods for Components and Objects (FMCO'03), 2004, Leiden, Netherlands. ⟨hal-00795036⟩
Share
Metrics
Record views
195
Files downloads
209
