A fully decoupled scheme for the interaction of a thin-walled structure with an incompressible fluid - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Comptes Rendus. Mathématique Année : 2013
In this note we propose a class of fully decoupled schemes (velocity-pressure-displacement splitting) for the coupling of an incompressible fluid with a thin-walled structure. The time splitting is achieved by combining an overall fractional-step time-marching of the system with a specific Robin-Neumann treatment of the interface coupling. The two variants considered yield unconditional stability. Numerical experiments in a benchmark show that, for one of them, the splitting does not compromises the optimal convergence rate.
paper.pdf (214.38 Ko) Télécharger le fichier
hal-00795585 , version 1 (28-02-2013)
Miguel Angel Fernández, Mikel Landajuela. A fully decoupled scheme for the interaction of a thin-walled structure with an incompressible fluid. Comptes Rendus. Mathématique, 2013, 351 (3-4), pp.161-164. ⟨10.1016/j.crma.2013.02.015⟩. ⟨hal-00795585⟩
257 Consultations
268 Téléchargements
