Monkey to human comparative anatomy of the frontal lobe association tracts. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Cortex Année : 2012
The greater expansion of the frontal lobes along the phylogeny scale has been interpreted as the signature of evolutionary changes underlying higher cognitive abilities in humans functions in humans. However, it is unknown how an increase in number of gyri, sulci and cortical areas in the frontal lobe have coincided with a parallel increase in connectivity. Here, using advanced tractography based on spherical deconvolution, we produced an atlas of human frontal association connections that we compared with axonal tracing studies of the monkey brain. We report several similarities between human and monkey in the cingulum, uncinate, superior longitudinal fasciculus, frontal aslant tract and orbito-polar tract. These similarities suggest to preserved functions across anthropoids. In addition, we found major differences in the arcuate fasciculus and the inferior fronto-occipital fasciculus. These differences indicate possible evolutionary changes in the connectional anatomy of the frontal lobes underlying unique human abilities.
hal-00795712 , version 1 (28-02-2013)
Michel Thiebaut de Schotten, Flavio Dell'Acqua, Romain Valabregue, Marco Catani. Monkey to human comparative anatomy of the frontal lobe association tracts.. Cortex, 2012, 48 (1), pp.82-96. ⟨10.1016/j.cortex.2011.10.001⟩. ⟨hal-00795712⟩
140 Consultations
0 Téléchargements
