Localized 1H NMR spectroscopy in different regions of human brain in vivo at 7 T: T2 relaxation times and concentrations of cerebral metabolites.
Abstract : At the high field strength of 7 T, in vivo spectra of the human brain with exceptional spectral quality sufficient to quantify 16 metabolites have been obtained previously only in the occipital lobe. However, neurochemical abnormalities associated with many brain disorders are expected to occur in brain structures other than the occipital lobe. The purpose of the present study was to obtain high-quality spectra from various brain regions at 7 T and to quantify the concentrations of different metabolites. To obtain concentrations of metabolites within four different regions of the brain, such as the occipital lobe, motor cortex, basal ganglia and cerebellum, the T(2) relaxation times of the singlets and J-coupled metabolites in these regions were measured for the first time at 7 T. Our results demonstrate that high-quality, quantifiable spectra can be obtained in regions other than the occipital lobe at 7 T utilizing a 16-channel transceiver coil and B(1)(+) shimming.
Type de document :
Article dans une revue
NMR in Biomedicine, Wiley, 2012, 25 (2), pp.332-339. 〈10.1002/nbm.1754〉
Liste complète des métadonnées
https://hal.inria.fr/hal-00795727
Contributeur : Olivier Colliot <>
Soumis le : jeudi 28 février 2013 - 18:33:14
Dernière modification le : samedi 8 décembre 2018 - 01:24:19
Lien texte intégral
Collections
Citation
Małgorzata Marjańska, Edward J Auerbach, Romain Valabrègue, Pierre-François Van de Moortele, Gregor Adriany, et al.. Localized 1H NMR spectroscopy in different regions of human brain in vivo at 7 T: T2 relaxation times and concentrations of cerebral metabolites.. NMR in Biomedicine, Wiley, 2012, 25 (2), pp.332-339. 〈10.1002/nbm.1754〉. 〈hal-00795727〉
Métriques
Consultations de la notice
86
