Spatial regularization of SVM for the detection of diffusion alterations associated with stroke outcome - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Medical Image Analysis Année : 2011
In this paper, we propose a new method to detect differences at the group level in brain images based on spatially regularized support vector machines (SVM). We propose to spatially regularize the SVM using a graph Laplacian. This provides a flexible approach to model different types of proximity between voxels. We propose a proximity graph which accounts for tissue types. An efficient computation of the Gram matrix is provided. Then, significant differences between two populations are detected using statistical tests on the outputs of the SVM. The method was first tested on synthetic examples. It was then applied to 72 stroke patients to detect brain areas associated with motor outcome at 90 days, based on diffusion-weighted images acquired at the acute stage (median delay one day). The proposed method showed that poor motor outcome is associated to changes in the corticospinal bundle and white matter tracts originating from the premotor cortex. Standard mass univariate analyses failed to detect any difference on the same population.
hal-00795741 , version 1 (28-02-2013)
Rémi Cuingnet, Charlotte Rosso, Marie Chupin, Stéphane Lehéricy, Didier Dormont, et al.. Spatial regularization of SVM for the detection of diffusion alterations associated with stroke outcome. Medical Image Analysis, 2011, 15 (5), pp.729-37. ⟨10.1016/j.media.2011.05.007⟩. ⟨hal-00795741⟩
127 Consultations
0 Téléchargements
