Approximating the discrete resource sharing scheduling problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Foundations of Computer Science Année : 2011
The goal of this work is to study the portfolio problem which consists in finding a good combination of multiple heuristics given a set of a problem instances to solve. We are interested in a parallel context where the resources are assumed to be discrete and homogeneous, and where it is not possible to allocate a given resource (processor) to more than one heuristic. The objective is to minimize the average completion time over the whole set of instances. We extend in this paper some existing analysis on the problem. More precisely, we provide a new complexity result for the restricted version of the problem, then, we generalize previous approximation schemes. In particular, they are improved using a guess approximation technique. Experimental results are also provided using a benchmark of instances on SAT solvers.
Fichier non déposé
hal-00796858 , version 1 (05-03-2013)
Marin Bougeret, Pierre-François Dutot, Alfredo Goldman, Yanik Ngoko, Denis Trystram. Approximating the discrete resource sharing scheduling problem. International Journal of Foundations of Computer Science, 2011, 22 (3), ⟨10.1142/s0129054111008271⟩. ⟨hal-00796858⟩
168 Consultations
0 Téléchargements
