New interface
Journal articles
Scheduling with uncertainties on new computing platforms
Abstract : New distributed computing platforms (grids) are based on interconnections of a large number of processing elements. A most important issue for their effective utilization is the optimal use of resources through proper task scheduling. It consists of allocating the tasks of a parallel program to processors on the platform and to determine at what time the tasks will start their execution. As data may be subject to uncertainties or disturbances, it is practically impossible to precisely predict the input parameters of the task scheduling problem. We briefly survey existing approaches for dealing with data uncertainties and discuss their relevance in the context of grid computing. We describe the stabilization process and analyze a scheduling algorithm that is intrinsically stable (i.e., it mitigates the effects of disturbances in input data at runtime). This algorithm is based on a decomposition of the application graph into convex sets of vertices. Finally, it is compared experimentally to pure on-line and well-known off-line algorithms.
Complete list of metadata
https://hal.inria.fr/hal-00796862
Contributor : Grégory Mounié Connect in order to contact the contributor
Submitted on : Tuesday, March 5, 2013 - 11:05:54 AM
Last modification on : Wednesday, July 6, 2022 - 4:11:50 AM
Links full text
Identifiers
Citation
Amine Mahjoub, Jonathan E. Pecero-Sanchez, Denis Trystram. Scheduling with uncertainties on new computing platforms. Computational Optimization and Applications, 2011, 48 (2), pp.369-398. ⟨10.1007/s10589-009-9311-0⟩. ⟨hal-00796862⟩
Share
Metrics
Record views
238
