The space of human body shapes: reconstruction and parameterization from range scans, Proc. of ACM SIGGRAPH, pp.587-594, 2003. ,
Swirling-Sweepers: Constant Volume Modeling, Graphical Models, vol.68, issue.4 2, pp.324-332, 2006. ,
An intuitive framework for real-time freeform modeling, ACM Transactions on Graphics, vol.23, issue.1 2, pp.630-634, 2004. ,
Primo: coupled prisms for intuitive surface modeling, Symposium on Geometry Processing, pp.11-20, 2006. ,
On linear variational surface deformation methods, IEEE Transactions on Visualization and Computer Graphics, vol.14, issue.1, pp.213-230, 2008. ,
Pattern-aware shape deformation using sliding dockers, ACM Transactions on Graphics, vol.30, issue.3 8, 2011. ,
A connection between partial symmetry and inverse procedural modeling ,
An algebraic model for parameterized shape editing, ACM Transactions on Graphics, vol.31, issue.3, p.8, 2012. ,
Interactive Shape Design. Synthesis Lectures on Computer Graphics and Animation, pp.1933-8996, 2002. ,
A bayesian method for probable surface reconstruction and decimation ,
A survey of spatial deformation from a user-centered perspective, ACM Transactions on Graphics, vol.27, issue.4 2, pp.1-21, 2008. ,
Discrete Shells, ACM SIGGRAPH / Eurographics Symposium on Computer Animation, pp.62-67, 2003. ,
iwires: An analyze-and-edit approach to shape manipulation ,
Subspace gradient domain mesh deformation, ACM Trans. Graph, vol.25, issue.2, pp.3-1126, 2006. ,
DOI : 10.1145/1179352.1142003
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.187.8830
Teddy: a sketching interface for 3d freeform design, Proceedings of ACM SIGGRAPH, pp.409-416, 1999. ,
Microtiles: Extracting building blocks from correspondences Non-homogeneous resizing of complex models, In Computer Graphics Forum (Proc. SGP) ACM Trans. Graph, vol.3, issue.2, pp.5-6, 2008. ,
Structure-preserving retargeting of irregular 3D architecture, ACM Transactions on Graphics, vol.30, issue.6 3, 2011. ,
Example-based elastic materials, Proc. SIGGRAPH), pp.1-72, 2011. ,
DOI : 10.1145/2010324.1964967
Interactive Physically-based Shape Editing, Computer Aided Geometric Design, issue.2, 2008. ,
Procedural modeling of buildings, ACM Transactions on Graphics, vol.25, issue.3, pp.614-623, 2006. ,
DOI : 10.1145/1141911.1141931
The Algorithmic Beauty of Plants, 1990. ,
Inverse procedural modeling by automatic generation of l-systems, Computer Graphics Forum, issue.3, 2010. ,
Laplacian surface editing, Proceedings of the 2004 Eurographics/ACM SIGGRAPH symposium on Geometry processing , SGP '04, pp.175-184, 2004. ,
DOI : 10.1145/1057432.1057456
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.132.2425
Sketch-based procedural surface modeling and compositing using Surface Trees, Proceedings of Eurographics, pp.321-330, 2008. ,
Embedded deformation for shape manipulation, SIGGRAPH '07: ACM SIGGRAPH 2007 papers, p.80, 2007. ,
Mesh-based inverse kinematics, Proc. of ACM SIG- GRAPH, vol.24, issue.3 2, pp.488-495, 2005. ,
Modeling inelastic deformation: viscolelasticity, plasticity, fracture, pp.269-278, 1988. ,
Elastically deformable models, Proc. SIGGRAPH '87, pp.205-214, 1987. ,
GeoBrush: Interactive Mesh Geometry Cloning, Computer Graphics Forum, vol.28, issue.5, pp.613-622, 2011. ,
DOI : 10.1111/j.1467-8659.2011.01883.x
Vector field based shape deformations, ACM Trans. Graph, vol.25, issue.3 2, pp.1118-1125, 2006. ,
Variational surface modeling, Computer Graphics (Proceedings Siggraph), 1992. ,
Joint-aware manipulation of deformable models, ACM Trans. Graph, vol.28, pp.3-4, 2009. ,
