New interface
Other publications
Simple Reed-Solomon Forward Error Correction (FEC) Scheme for FECFRAME
Abstract : This document describes a fully-specified simple Forward Error Correction (FEC) scheme for Reed-Solomon codes over the finite field (also known as the Galois Field) GF(2^^m), with 2 <= m <= 16, that can be used to protect arbitrary media streams along the lines defined by FECFRAME. The Reed-Solomon codes considered have attractive properties, since they offer optimal protection against packet erasures and the source symbols are part of the encoding symbols, which can greatly simplify decoding. However, the price to pay is a limit on the maximum source block size, on the maximum number of encoding symbols, and a computational complexity higher than that of the Low-Density Parity Check (LDPC) codes, for instance.
Document type :
Other publications
Complete list of metadata
Cited literature [12 references]  Display  Hide  Download
https://hal.inria.fr/hal-00799727
Contributor : Vincent Roca Connect in order to contact the contributor
Submitted on : Tuesday, March 12, 2013 - 3:34:04 PM
Last modification on : Tuesday, July 5, 2022 - 9:31:37 AM
Long-term archiving on: : Monday, June 17, 2013 - 12:13:49 PM
File
rfc6865.pdf
Identifiers
  • HAL Id : hal-00799727, version 1
Collections
Citation
Vincent Roca, Mathieu Cunche, Jérôme Lacan, Amine Bouabdallah, Kazuhisa Matsuzono. Simple Reed-Solomon Forward Error Correction (FEC) Scheme for FECFRAME. 2013. ⟨hal-00799727⟩
Share
Metrics
Record views
354
Files downloads
564
