On relations of the adjoint state to the value function for optimal control problems with state constraints
Hélène Frankowska 1 Marco Mazzola 1
1 C&O - Equipe combinatoire et optimisation
UPMC - Université Pierre et Marie Curie - Paris 6, CNRS - Centre National de la Recherche Scientifique : FRE3232
Abstract : We consider an optimal control problem under state constraints and show that to every optimal solution corresponds an adjoint state satisfying the first order necessary optimality conditions in the form of a maximum principle and sensitivity relations involving the value function. Such sensitivity relations were recently investigated by P. Bettiol and R.B. Vinter for state constraints with smooth boundary. In the difference with their work, our setting concerns differential inclusions and nonsmooth state constraints. To obtain our result we derive neighboring feasible trajectory estimates using a novel generalization of the so-called inward pointing condition.
Type de document :
Article dans une revue
Nonlinear Differential Equations and Applications, Springer Verlag, 2013, 20, pp.361-383. 〈10.1007/s00030-012-0183-0〉
Liste complète des métadonnées
https://hal.inria.fr/hal-00800199
Contributeur : Estelle Bouzat <>
Soumis le : mercredi 13 mars 2013 - 13:03:25
Dernière modification le : jeudi 11 janvier 2018 - 06:20:24
Collections
Citation
Hélène Frankowska, Marco Mazzola. On relations of the adjoint state to the value function for optimal control problems with state constraints. Nonlinear Differential Equations and Applications, Springer Verlag, 2013, 20, pp.361-383. 〈10.1007/s00030-012-0183-0〉. 〈hal-00800199〉
Métriques
Consultations de la notice
275
