New interface
Journal articles
Idle regulation in non-clairvoyant scheduling of parallel jobs
Abstract : The optimization of parallel applications is difficult to achieve by classical optimization techniques because of their diversity and the variety of actual parallel and distributed platforms and/or environments. Adaptive algorithmic schemes, capable of dynamically changing the allocation of jobs during the execution to optimize global system behavior, are the best alternatives for solving this problem. In this paper, we focus on non-clairvoyant scheduling of parallel jobs with known resource requirements but unknown running times, with emphasis on the regulation of idle periods in the context of general list policies. We consider a new family of scheduling strategies based on two phases which successively combine sequential and parallel execution of jobs. We generalize known worst-case performance bounds by considering two extra parameters, in addition to the number of processors and maximum processor requirements considered in the literature, namely, job parallelization penalty and idle regulation factor. Furthermore, we prove that under certain conditions of idle regulation, the performance guarantee of parallel job scheduling in space-sharing mode can be improved.
Complete list of metadata
https://hal.inria.fr/hal-00800416
Contributor : Grégory Mounié Connect in order to contact the contributor
Submitted on : Wednesday, March 13, 2013 - 4:30:46 PM
Last modification on : Tuesday, November 29, 2022 - 12:08:09 PM
Links full text
Identifiers
Citation
Andrei Tchernykh, Denis Trystram, C. Brizuela, Isaac Scherson. Idle regulation in non-clairvoyant scheduling of parallel jobs. Discrete Applied Mathematics, 2009, 157, pp.364-376. ⟨10.1016/j.dam.2008.03.005⟩. ⟨hal-00800416⟩
Share
Metrics
Record views
104
