New interface
Book sections
An adaptive POD approximation method for the control of advection-diffusion equations
Abstract : We present an algorithm for the approximation of a finite horizon optimal control problem for advection-diffusion equations. The method is based on the coupling between an adaptive POD representation of the solution and a Dynamic Programming approximation scheme for the corresponding evolutive Hamilton-Jacobi equation. We discuss several features regarding the adaptivity of the method, the role of error estimate indicators to choose a time subdivision of the problem and the computation of the basis functions. Some test problems are presented to illustrate the method.
Document type :
Book sections
Complete list of metadata
https://hal.inria.fr/hal-00800433
Contributor : Estelle Bouzat Connect in order to contact the contributor
Submitted on : Wednesday, March 13, 2013 - 4:23:37 PM
Last modification on : Friday, November 25, 2022 - 7:04:09 PM
Links full text
Identifiers
  • HAL Id : hal-00800433, version 1
  • ARXIV : 1302.4072
Collections
Citation
Alessandro Alla, Maurizio Falcone. An adaptive POD approximation method for the control of advection-diffusion equations. Bredies, K.; Clason, C.; Kunisch, K.; von Winckel, G. Control and Optimization with PDE Constraints, 164, Springer, 2013, International Series of Numerical Mathematics,, 978-3-0348-0630-5. ⟨hal-00800433⟩
Share
Metrics
Record views
81
