Comparison of Numerical Methods in the Contrast Imaging Problem in NMR - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this article, the contrast imaging problem in nuclear magnetic resonance is modeled as a Mayer problem in optimal control. A first synthesis of locally optimal solutions is given in the single-input case using geometric methods based on Pontryagin's maximum principle. We then compare these results using direct methods and a moment-based approach, and make a first step towards global optimality. Finally, some preliminary results are given in the bi-input case.
root.pdf (449.72 Ko) Télécharger le fichier
hal-00800436 , version 1 (13-03-2013)
  • HAL Id : hal-00800436 , version 1
Bernard Bonnard, Mathieu Claeys, Olivier Cots, Pierre Martinon. Comparison of Numerical Methods in the Contrast Imaging Problem in NMR. 52nd IEEE Conference on Decision and Control, Dec 2013, Firenze, Italy. ⟨hal-00800436⟩
648 Consultations
382 Téléchargements
