A Godunov-Type Solver for the Numerical Approximation of Gravitational Flows - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Communications in Computational Physics Année : 2014
We present a new numerical method to approximate the solutions of an Euler-Poisson model, which is inherent to astrophysical flows where gravity plays an important role. We propose a discretization of gravity which ensures adequate coupling of the Poisson and Euler equations, paying particular attention to the gravity source term involved in the latter equations. In order to approximate this source term, its discretization is introduced into the approximate Riemann solver used for the Euler equations. A relaxation scheme is involved and its robustness is established. The method has been implemented in the software HERACLES and several numerical experiments involving gravitational flows for astrophysics highlight the scheme.
euler_poisson_first_hal_.pdf (1.46 Mo) Télécharger le fichier
hal-00800474 , version 1 (13-03-2013)
Jeaniffer Vides, Benjamin Braconnier, Edouard Audit, Christophe Berthon, Boniface Nkonga. A Godunov-Type Solver for the Numerical Approximation of Gravitational Flows. Communications in Computational Physics, 2014, 15 (1), pp.46-75. ⟨10.4208/cicp.060712.210313a⟩. ⟨hal-00800474⟩
947 Consultations
653 Téléchargements
