Numerical approximation of Kerr-Debye equations, p.293728 ,
URL : https://hal.archives-ouvertes.fr/hal-00293728
On the Dynamical Foundations of ?? Disks, The Astrophysical Journal, vol.521, issue.2, p.650, 1999. ,
DOI : 10.1086/307594
A relaxation method for two-phase flow models with hydrodynamic closure law, Numerische Mathematik, vol.48, issue.3, pp.99-411, 2005. ,
DOI : 10.1007/s00211-004-0558-1
Stability of the MUSCL Schemes for the Euler Equations, Communications in Mathematical Sciences, vol.3, issue.2, pp.133-158, 2005. ,
DOI : 10.4310/CMS.2005.v3.n2.a3
Robustness of MUSCL schemes for 2D unstructured meshes, Journal of Computational Physics, vol.218, issue.2, pp.495-509, 2006. ,
DOI : 10.1016/j.jcp.2006.02.028
Numerical approximations of the 10-moment Gaussian closure, Mathematics of Computation, vol.75, issue.256, pp.1809-1831, 2006. ,
DOI : 10.1090/S0025-5718-06-01860-6
Numerical approximation of a degenerated non-conservative multifluid model: relaxation scheme, International Journal for Numerical Methods in Fluids, vol.48, issue.1, pp.85-90, 2005. ,
DOI : 10.1002/fld.933
A relaxation scheme for the approximation of the pressureless Euler equations, Numerical Methods for Partial Differential Equations, vol.118, issue.2, pp.484-505, 2006. ,
DOI : 10.1002/num.20108
An HLLC scheme to solve the M1 Model of radiative transfer in two space dimensions, J. Sci. Comput, pp.31-347, 2007. ,
URL : https://hal.archives-ouvertes.fr/hal-00293559
A Positive Preserving High Order VFRoe Scheme for Shallow Water Equations: A Class of Relaxation Schemes, SIAM Journal on Scientific Computing, vol.30, issue.5, pp.2587-2612, 2008. ,
DOI : 10.1137/070686147
URL : https://hal.archives-ouvertes.fr/hal-00370486
Entropy satisfying flux vector splittings and kinetic BGK models, Numerische Mathematik, vol.94, issue.4, pp.623-672, 2003. ,
DOI : 10.1007/s00211-002-0426-9
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.33.3361
Nonlinear Stability of Finite Volume Methods for Hyperbolic Conservation Laws, and Well-Balanced Schemes for Sources, Frontiers in Mathematics, 2004. ,
An entropy satisfying scheme for two-layer shallow water equations with uncoupled treatment, ESAIM: Mathematical Modelling and Numerical Analysis, vol.42, issue.4, pp.2-42, 2008. ,
DOI : 10.1051/m2an:2008019
Navier-Stokes equations with several independent pressure laws and explicit predictor-corrector schemes, Numerische Mathematik, vol.36, issue.3, pp.451-478, 2005. ,
DOI : 10.1007/s00211-005-0612-7
URL : https://hal.archives-ouvertes.fr/hal-00112166
Relaxation approximation of the Euler equations, Journal of Mathematical Analysis and Applications, vol.348, issue.2, pp.872-893, 2008. ,
DOI : 10.1016/j.jmaa.2008.07.034
Hyperbolic conservation laws with stiff relaxation terms and entropy, Communications on Pure and Applied Mathematics, vol.44, issue.6, pp.47-787, 1995. ,
DOI : 10.1002/cpa.3160470602
Elements of Hydrodynamics Applied to the Interstellar Medium, Starbursts: Triggers, Nature, and Evolution, Les Houches School, ESP Sciences, p.77, 1996. ,
Relaxation of Energy and Approximate Riemann Solvers for General Pressure Laws in Fluid Dynamics, SIAM Journal on Numerical Analysis, vol.35, issue.6, pp.2223-2249, 1998. ,
DOI : 10.1137/S0036142997318528
An asymptotically stable discretization for the Euler-Poisson system in the quasineutral limit, C. R. Acad. Sci. Paris Ser. I, pp.323-328, 2005. ,
An asymptotic preserving scheme for the two-fluid Euler???Poisson model in the quasineutral limit, Journal of Computational Physics, vol.223, issue.1, pp.208-234, 2007. ,
DOI : 10.1016/j.jcp.2006.09.004
URL : https://hal.archives-ouvertes.fr/hal-00635602
An Asymptotic Preserving scheme for the Euler equations in a strong magnetic field, Journal of Computational Physics, vol.228, issue.10, pp.3540-3558, 2009. ,
DOI : 10.1016/j.jcp.2008.12.040
URL : https://hal.archives-ouvertes.fr/hal-00319630
Mach-number uniform asymptotic-preserving Gauge schemes for compressible flows, Bull. Inst. Math., Acad. Sinica (New Series), vol.2, pp.851-892, 2007. ,
URL : https://hal.archives-ouvertes.fr/hal-00635618
Analysis of an Asymptotic Preserving Scheme for the Euler???Poisson System in the Quasineutral Limit, SIAM Journal on Numerical Analysis, vol.46, issue.3, pp.46-1298, 2008. ,
DOI : 10.1137/070690584
URL : https://hal.archives-ouvertes.fr/hal-00635071
Stability analysis of the Euler-poisson equations, Journal of Computational Physics, vol.101, issue.2, pp.445-451, 1992. ,
DOI : 10.1016/0021-9991(92)90020-Y
Some approximate Godunov schemes to compute shallowwater equations with topography, pp.479-513, 2003. ,
URL : https://hal.archives-ouvertes.fr/hal-01290889
On a well-balanced high-order finite volume scheme for shallow water equations with topography and dry areas, Journal of Computational Physics, vol.227, issue.1, pp.574-601, 2007. ,
DOI : 10.1016/j.jcp.2007.08.007
Hyperbolic systems of conservations laws, Applied Mathematical Sciences, vol.118, 1996. ,
HERACLES: a three-dimensional radiation hydrodynamics code, Astronomy and Astrophysics, vol.464, issue.2, pp.429-435, 2007. ,
DOI : 10.1051/0004-6361:20065486
A Well-Balanced Scheme for the Numerical Processing of Source Terms in Hyperbolic Equations, SIAM Journal on Numerical Analysis, vol.33, issue.1, pp.1-16, 1996. ,
DOI : 10.1137/0733001
Analysis and Approximation of Conservation Laws with Source Terms, SIAM Journal on Numerical Analysis, vol.34, issue.5, pp.1980-2007, 1997. ,
DOI : 10.1137/S0036142995286751
Van Leer, On upstream differencing and Godunov-type schemes for hyperbolic conservation laws, SIAM, vol.25, pp.33-61, 1983. ,
The solution of poisson's equation for isolated source distributions, Journal of Computational Physics, vol.25, issue.2, pp.71-93, 1977. ,
DOI : 10.1016/0021-9991(77)90013-4
A steady-state capturing method for hyperbolic systems with geometrical source terms, ESAIM: Mathematical Modelling and Numerical Analysis, vol.35, issue.4, pp.631-645, 2001. ,
DOI : 10.1051/m2an:2001130
The relaxation schemes for systems of conservation laws in arbitrary space dimensions, Communications on Pure and Applied Mathematics, vol.54, issue.3, pp.235-278, 1995. ,
DOI : 10.1002/cpa.3160480303
Balancing Source Terms and Flux Gradients in High-Resolution Godunov Methods: The Quasi-Steady Wave-Propagation Algorithm, Journal of Computational Physics, vol.146, issue.1, pp.346-365, 1998. ,
DOI : 10.1006/jcph.1998.6058
A Class of Approximate Riemann Solvers and Their Relation to Relaxation Schemes, Journal of Computational Physics, vol.172, issue.2, pp.572-591, 2001. ,
DOI : 10.1006/jcph.2001.6838
URL : https://hal.archives-ouvertes.fr/hal-01342280
Convergence of the nonisentropic Euler???Poisson equations to incompressible type Euler equations, Journal of Mathematical Analysis and Applications, vol.342, issue.2, pp.1107-1125, 2008. ,
DOI : 10.1016/j.jmaa.2007.12.067
Convergence of a singular Euler-Poisson approximation of the incompressible Navier-Stokes equations, Proc. Amer, pp.2251-2258, 2006. ,
URL : https://hal.archives-ouvertes.fr/hal-00458157
Well-balanced finite volume schemes of arbitrary order of accuracy for shallow water flows, Journal of Computational Physics, vol.213, issue.2, pp.474-499, 2006. ,
DOI : 10.1016/j.jcp.2005.08.019
Characteristic-Based Schemes for the Euler Equations, Annual Review of Fluid Mechanics, vol.18, issue.1, pp.337-365, 1986. ,
DOI : 10.1146/annurev.fl.18.010186.002005
On modelling phase transitions by means of rate-type constitutive equations. Shock wave structure, International Journal of Engineering Science, vol.28, issue.8, pp.28-829, 1990. ,
DOI : 10.1016/0020-7225(90)90028-H
Some stability-instability problems in phase transitions modelled by piecewise linear elastic or viscoelastic constitutive equations, International Journal of Engineering Science, vol.30, issue.4, pp.483-494, 1992. ,
DOI : 10.1016/0020-7225(92)90039-J
Positivity-Preserving Schemes in Multidimensions, SIAM Journal on Scientific Computing, vol.22, issue.4, pp.1184-1198, 2000. ,
DOI : 10.1137/S1064827599360443
Towards the ultimate conservative difference scheme. II. Monotonicity and conservation combined in a second-order scheme, Journal of Computational Physics, vol.14, issue.4, pp.361-70, 1974. ,
DOI : 10.1016/0021-9991(74)90019-9
Towards the ultimate conservative difference scheme. V. A second-order sequel to Godunov's method, Journal of Computational Physics, vol.32, issue.1, pp.101-136, 1979. ,
DOI : 10.1016/0021-9991(79)90145-1
On the Relation Between the Upwind-Differencing Schemes of Godunov, Engquist???Osher and Roe, SIAM Journal on Scientific and Statistical Computing, vol.5, issue.1, pp.1-20, 1984. ,
DOI : 10.1137/0905001
