New interface
Conference papers
A Semi-Lagrangian scheme for area preserving flows
Abstract : We propose a new Semi-Lagrangian scheme for the area-preserving Mean Curvature flow. The model uses a level set framework to propagate a closed planar curve. The corresponding flow has been proposed by Sapiro & Tannenbaum [9]. The scheme has the advantage to allow large time step still maintaining a good accuracy. We apply the algorithm to recover the original shape of a synthetic image to which artificial noise has been added. The numerical result shows that the area is preserved during the filtering process.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/hal-00800487
Contributor : Estelle Bouzat Connect in order to contact the contributor
Submitted on : Wednesday, March 13, 2013 - 5:01:38 PM
Last modification on : Friday, November 25, 2022 - 7:04:09 PM
Identifiers
  • HAL Id : hal-00800487, version 1
Collections
Citation
Elisabetta Carlini, Roberto Ferretti. A Semi-Lagrangian scheme for area preserving flows. 21st International Conference on Pattern Recognition (ICPR2012), 2012, Tsupuka, Japan. pp.2029 - 2033. ⟨hal-00800487⟩
Share
Metrics
Record views
39
