A Semi-Lagrangian scheme for area preserving flows
Abstract : We propose a new Semi-Lagrangian scheme for the area-preserving Mean Curvature flow. The model uses a level set framework to propagate a closed planar curve. The corresponding flow has been proposed by Sapiro & Tannenbaum [9]. The scheme has the advantage to allow large time step still maintaining a good accuracy. We apply the algorithm to recover the original shape of a synthetic image to which artificial noise has been added. The numerical result shows that the area is preserved during the filtering process.
Type de document :
Communication dans un congrès
21st International Conference on Pattern Recognition (ICPR2012), 2012, Tsupuka, Japan. pp.2029 - 2033, 2012, Proceedings of the 21 International Conference on Pattern recognition
Liste complète des métadonnées
https://hal.inria.fr/hal-00800487
Contributeur : Estelle Bouzat <>
Soumis le : mercredi 13 mars 2013 - 17:01:38
Dernière modification le : lundi 21 mars 2016 - 11:30:06
  • HAL Id : hal-00800487, version 1
Collections
Citation
Elisabetta Carlini, Roberto Ferretti. A Semi-Lagrangian scheme for area preserving flows. 21st International Conference on Pattern Recognition (ICPR2012), 2012, Tsupuka, Japan. pp.2029 - 2033, 2012, Proceedings of the 21 International Conference on Pattern recognition. <hal-00800487>
Métriques
Consultations de la notice
70
