Nonlinear MPC and MHE for Mechanical Multi-Body Systems with Application to Fast Tethered Airplanes
Abstract : Mechanical applications often require a high control frequency to cope with fast dynamics. The control frequency of a nonlinear model predictive controller depends strongly on the symbolic complexity of the equations modeling the system. The symbolic complexity of the model equations for multi-body mechanical systems can often be dramatically reduced by using representations based on non-minimal coordinates, which result in index-3 differential-algebraic equations (DAEs). This paper proposes a general procedure to efficiently treat multi-body mechanical systems in the context of real-time NMPC, using non-minimal coordinate representations.
Type de document :
Communication dans un congrès
IFAC Conference on Nonlinear Model Predictive Control 2012 (NMPC'12, 2012, Leeuwenhorst, Netherlands. IFAC, 4(1), pp.86-93, 2012, Nonlinear Model Predictive Control. <10.3182/20120823-5-NL-3013.00061>
Liste complète des métadonnées
https://hal.inria.fr/hal-00800498
Contributeur : Estelle Bouzat <>
Soumis le : mercredi 13 mars 2013 - 17:27:16
Dernière modification le : lundi 21 mars 2016 - 11:30:33
Collections
Citation
Sebastien Gros, Mario Zanon, Moritz Diehl. Nonlinear MPC and MHE for Mechanical Multi-Body Systems with Application to Fast Tethered Airplanes. IFAC Conference on Nonlinear Model Predictive Control 2012 (NMPC'12, 2012, Leeuwenhorst, Netherlands. IFAC, 4(1), pp.86-93, 2012, Nonlinear Model Predictive Control. <10.3182/20120823-5-NL-3013.00061>. <hal-00800498>
Métriques
Consultations de la notice
130
