Optimal Control of Growth and Climate Change--Exploration of Scenarios - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2013
Johann Jakob Preuss
  • Fonction : Auteur
Willi Semmler
  • Fonction : Auteur
The paper uses a well-known canonical dynamic model of growth and climate change and explores various scenarios of mitigation policies. Whereas the Kyoto protocol was aiming at CO2 constraints, the Copenhagen agreement pursued temperature constraints. We study the practicality and implication of those and other policy scenarios. For doing so we need to admit terminal constraints for the state variables, consider the impacts of state and control constraints on abatement policies and consumption paths. We also explore a temperature penalty effect on consumption. The different scenarios are studied as guidance for policy options. We compare solutions for finite horizon and infinite horizon. State and control trajectories of infinite-horizon control problems are computed using the routine opttrj in (Kunkel and van dem Hagen, Comput. Econ. 16:189-205, 2000), whereas solutions of finite-horizon control problems with control and state constraints are obtained by discretization and nonlinear programming methods.
Fichier non déposé
hal-00800532 , version 1 (13-03-2013)
Helmut Maurer, Johann Jakob Preuss, Willi Semmler. Optimal Control of Growth and Climate Change--Exploration of Scenarios. Jesús Crespo Cuaresma, Tapio Palokangas, Alexander Tarasyev. Green Growth and Sustainable Development, 14, Springer, pp.113-139, 2013, Dynamic Modeling and Econometrics in Economics and Finance, 978-3-642-34353-7. ⟨10.1007/978-3-642-34354-4_6⟩. ⟨hal-00800532⟩
Collections
SADCO TDS-MACS
196 Consultations
0 Téléchargements
