New interface
Journal articles
Using deconvolution to improve the metrological performance of the grid method
Michel Grediac 1, * Frédéric Sur 2 Claudiu Badulescu 3 Jean-Denis Mathias 4
* Corresponding author
2 MAGRIT - Visual Augmentation of Complex Environments
Inria Nancy - Grand Est, LORIA - ALGO - Department of Algorithms, Computation, Image and Geometry
3 MMA
LBMS - Laboratoire brestois de mécanique et des systèmes
Abstract : The use of various deconvolution techniques to enhance strain maps obtained with the grid method is addressed in this study. Since phase derivative maps obtained with the grid method can be approximated by their actual counterparts convolved by the envelope of the kernel used to extract phases and phase derivatives, non-blind restoration techniques can be used to perform deconvolution. Six deconvolution techniques are presented and employed to restore a synthetic phase derivative map, namely direct deconvolution, regularized deconvolution, Richardson-Lucy algorithm and Wiener filtering, the last two with two variants concerning their practical implementations. Obtained results show that the noise that corrupts the grid images must be thoroughly taken into account to limit its effect on the deconvolved strain maps. The difficulty here is that the noise on the grid image yields a spatially correlated noise on the strain maps. In particular, numerical experiments on synthetic data show that direct and regularized deconvolutions are unstable when noisy data are processed. The same remark holds when Wiener filtering is employed without taking into account noise autocorrelation. On the other hand, the Richardson-Lucy algorithm and Wiener filtering with noise autocorrelation provide deconvolved maps where the impact of noise remains controlled within a certain limit. It is also observed that the last technique outperforms the Richardson-Lucy algorithm. Two short examples of actual strain fields restoration are finally shown. They deal with asphalt and shape memory alloy specimens. The benefits and limitations of deconvolution are presented and discussed in these two cases. The main conclusion is that strain maps are correctly deconvolved when the signal-to-noise ratio is high and that actual noise in the actual strain maps must be more specifically characterized than in the current study to address higher noise levels with Wiener filtering.
Complete list of metadata
Cited literature [28 references]  Display  Hide  Download
https://hal.inria.fr/hal-00801133
Contributor : Frédéric Sur Connect in order to contact the contributor
Submitted on : Friday, March 15, 2013 - 10:31:11 AM
Last modification on : Tuesday, October 25, 2022 - 4:16:19 PM
Long-term archiving on: : Monday, June 17, 2013 - 2:22:10 PM
File
OLEN_authors.pdf
Identifiers
Citation
Michel Grediac, Frédéric Sur, Claudiu Badulescu, Jean-Denis Mathias. Using deconvolution to improve the metrological performance of the grid method. Optics and Lasers in Engineering, 2013, 51 (6), pp.716-734. ⟨10.1016/j.optlaseng.2013.01.009⟩. ⟨hal-00801133⟩
Share
Metrics
Record views
506
Files downloads
87
