Fractional system identification for lead acid battery state of charge estimation, Signal Processing, vol.86, issue.10, pp.2645-2657, 2006. ,
DOI : 10.1016/j.sigpro.2006.02.030
Fractional modelling and identification of thermal systems, Signal Processing, vol.91, issue.3, pp.531-541, 2011. ,
DOI : 10.1016/j.sigpro.2010.02.005
Identification of a thermal system using continuous linear parameter-varying fractional modelling, IET Control Theory & Applications, pp.889-899, 2011. ,
Identification of non integer order system in the time domain, proceeding IEEE CESA'96, SMC IMACS Multiconference, Computational Engineering in Systems Application , Symposium on Control, Optimisation and Supervision, 1996. ,
Recursive prediction error identification of fractional order models, Communications in Nonlinear Science and Numerical Simulation, vol.17, issue.6, pp.2517-2524, 2012. ,
DOI : 10.1016/j.cnsns.2011.08.015
Modeling and identification of a non integer order system, Proceedings of the ECC99,European Control Conference, 1999. ,
Synthesis of fractional Laguerre basis for system approximation, Automatica, vol.43, issue.9, pp.1640-1648, 2007. ,
DOI : 10.1016/j.automatica.2007.02.013
URL : https://hal.archives-ouvertes.fr/hal-00180684
Fractional state variable filter for system identification by fractional model, IEEE 6th European Control Conference ECC2001, 2001. ,
Non integer model from modal decomposition for time domain system identification, proceedings of 12th IFAC Symposium on System Identification, 2000. ,
TUTORIAL ON SYSTEM IDENTIFICATION USING FRACTIONAL DIFFERENTIATION MODELS, IFAC Proceedings Volumes, vol.39, issue.1, 1954. ,
DOI : 10.3182/20060329-3-AU-2901.00093
URL : https://hal.archives-ouvertes.fr/hal-00180699
On the analysis of linear and nonlinear systems, Trans. ASME, pp.547-552, 1957. ,
Generalization of modulating functions method in the fractional differential equations, Bulletin of the academy of Sciences, pp.593-599, 2010. ,
Theory and application of the modulating function method???I. Review and theory of the method and theory of the spline-type modulating functions, Computers & Chemical Engineering, vol.17, issue.1, pp.1-16, 1993. ,
DOI : 10.1016/0098-1354(93)80001-4
Adjoint Fractional Differential Expressions and Operators, Volume 5: 6th International Conference on Multibody Systems, Nonlinear Dynamics, and Control, Parts A, B, and C, 2007. ,
DOI : 10.1115/DETC2007-35005
An algebraic framework for linear identification, ESAIM: Control, Optimisation and Calculus of Variations, vol.9, pp.151-168, 2003. ,
DOI : 10.1051/cocv:2003008
Closed-loop parametric identification for continuous-time linear systems via new algebraic techniques Identification of Continuous-time Models from Sampled Data, pp.363-391, 2008. ,
Parameter estimation for signals described by differential equations, Applicable Analysis, vol.26, issue.1, pp.29-52, 2009. ,
DOI : 10.1109/MED.2008.4602161
Parameters estimation of a noisy sinusoidal signal with time-varying amplitude, 2011 19th Mediterranean Conference on Control & Automation (MED), 2011. ,
DOI : 10.1109/MED.2011.5983186
URL : https://hal.archives-ouvertes.fr/inria-00593408
An error analysis in the algebraic estimation of a noisy sinusoidal signal, 2008 16th Mediterranean Conference on Control and Automation, 2008. ,
URL : https://hal.archives-ouvertes.fr/inria-00300234
Algebraic parameter estimation of a biased sinusoidal waveform signal from noisy data, 16th IFAC Symposium on System Identification, 2012. ,
DOI : 10.3182/20120711-3-BE-2027.00393
URL : https://hal.archives-ouvertes.fr/hal-00685067
An algebraic approach for Humane posture estimation in the sagital plane using accelerometer noisy signal, 51st IEEE Conference on Decision and Control, 2012. ,
An algebraic frequency estimator for a biased and noisy sinusoidal signal, Signal Processing, vol.87, issue.6, pp.1188-1201, 2007. ,
DOI : 10.1016/j.sigpro.2006.10.006
Error analysis of Jacobi derivative estimators for noisy signals, Numerical Algorithms, vol.21, issue.12, pp.53-83, 2011. ,
DOI : 10.1007/s11075-011-9447-8
URL : https://hal.archives-ouvertes.fr/inria-00573270
System Identification: Theory for the User, 1999. ,
Digital Fractional Order Savitzky-Golay Differentiator, IEEE Transactions on Circuits and Systems II: Express Briefs, vol.58, issue.11, pp.758-762, 2011. ,
DOI : 10.1109/TCSII.2011.2168022
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.648.5648
Fractional order differentiation by integration with Jacobi polynomials, 2012 IEEE 51st IEEE Conference on Decision and Control (CDC), 2012. ,
DOI : 10.1109/CDC.2012.6426436
URL : https://hal.archives-ouvertes.fr/hal-00728406
Non-asymptotic fractional order differentiators via an algebraic parametric method, 2012 1st International Conference on Systems and Computer Science (ICSCS), 2012. ,
DOI : 10.1109/IConSCS.2012.6502445
URL : https://hal.archives-ouvertes.fr/hal-00713338
Analyse non standard du bruit, Comptes Rendus Mathematique, vol.342, issue.10, pp.797-802, 2006. ,
DOI : 10.1016/j.crma.2006.02.037
URL : https://hal.archives-ouvertes.fr/inria-00001134
An Introduction to the Fractional Calculus and Fractional Differential Equations, 1993. ,
