Journal articles
Efficiency of simulation in monotone hyper-stable queueing networks
Jonatha Anselmi 1, 2 Bruno Gaujal 3
1 CQFD - Quality control and dynamic reliability
IMB - Institut de Mathématiques de Bordeaux, Inria Bordeaux - Sud-Ouest
3 MESCAL - Middleware efficiently scalable
Inria Grenoble - Rhône-Alpes, LIG - Laboratoire d'Informatique de Grenoble
Abstract : We consider Jackson queueing networks with finite buffer constraints (JQN) and analyze the efficiency of sampling from their stationary distribution. In the context of exact sampling, the monotonicity structure of JQNs ensures that such efficiency is of the order of the coupling time (or meeting time) of two extremal sample paths. In the context of approximate sampling, it is given by the mixing time. Under a condition on the drift of the stochastic process underlying a JQN, which we call hyper-stability, in our main result we show that the coupling time is polynomial in both the number of queues and buffer sizes. Then, we use this result to show that the mixing time of JQNs behaves similarly up to a given precision threshold. Our proof relies on a recursive formula relating the coupling times of trajectories that start from network states having 'distance one', and it can be used to analyze the coupling and mixing times of other Markovian networks, provided that they are monotone. An illustrative example is shown in the context of JQNs with blocking mechanisms.
Complete list of metadata
Cited literature [22 references]  Display  Hide  Download
https://hal.archives-ouvertes.fr/hal-01102977
Contributor : Jonatha Anselmi Connect in order to contact the contributor
Submitted on : Tuesday, January 13, 2015 - 5:23:18 PM
Last modification on : Wednesday, July 6, 2022 - 4:21:34 AM
Long-term archiving on: : Tuesday, April 14, 2015 - 11:25:49 AM
File
couplingtime.pdf
Identifiers
Collections
Citation
Jonatha Anselmi, Bruno Gaujal. Efficiency of simulation in monotone hyper-stable queueing networks. Queueing Systems, Springer Verlag, 2014, 76 (1), pp.51-72. ⟨10.1007/s11134-013-9357-7⟩. ⟨hal-01102977⟩
Share
Metrics
Record views
333
Files downloads
199
