An Implicit Enumeration Algorithm for Quadratic Integer Programming, Management Science, vol.26, issue.3, pp.282-296, 1980. ,
DOI : 10.1287/mnsc.26.3.282
On the notion of balance of a signed graph., The Michigan Mathematical Journal, vol.2, issue.2, pp.143-146, 1953. ,
DOI : 10.1307/mmj/1028989917
Computer-aided layout design, Mathematical Programming in Use Mathematical Programming Studies, vol.9, issue.6, pp.75-94, 1978. ,
DOI : 10.1007/BFb0120827
A Decomposition Method for Quadratic Zero-One Programming, Management Science, vol.41, issue.4, pp.704-712, 1994. ,
DOI : 10.1287/mnsc.41.4.704
A unified modeling and solution framework for combinatorial optimization problems, OR Spectrum, vol.26, issue.2, pp.237-250, 2004. ,
DOI : 10.1007/s00291-003-0153-3
A new modeling and solution approach for the set-partitioning problem, Computers & Operations Research, vol.35, issue.3, pp.807-813, 2008. ,
DOI : 10.1016/j.cor.2006.04.002
Computers and Intractability: A Guide to the Theory of NP-Completeness, 1979. ,
A max-flow approach to improved lower bounds for quadratic unconstrained binary optimization (QUBO), Discrete Optimization, vol.5, issue.2, pp.501-529, 2008. ,
DOI : 10.1016/j.disopt.2007.02.001
Solving quadratic (0,1)-problems by semidefinite programs and cutting planes, Mathematical Programming, vol.62, issue.115, pp.291-315, 1998. ,
DOI : 10.1007/BF01580072
Rechnerische Aspekte eines ???Branch and Bound???-Algorithmus zur quadratischen Null-Eins-Programmierung, Computing, vol.5, issue.3, pp.131-144, 1990. ,
DOI : 10.1007/BF02247879
Performance of simulated annealing-based heuristic for the unconstrained binary quadratic programming problem, European Journal of Operational Research, vol.134, issue.1, pp.103-119, 2001. ,
DOI : 10.1016/S0377-2217(00)00242-3
Adaptive Memory Tabu Search for Binary Quadratic Programs, Management Science, vol.44, issue.3, pp.336-345, 1998. ,
DOI : 10.1287/mnsc.44.3.336
Diversification-driven tabu search for unconstrained binary quadratic problems, 4OR, vol.4, issue.2, pp.239-253, 2010. ,
DOI : 10.1007/s10288-009-0115-y
Multistart Tabu Search Strategies for the Unconstrained Binary Quadratic Optimization Problem, Annals of Operations Research, vol.131, issue.1-4, pp.259-282, 2004. ,
DOI : 10.1023/B:ANOR.0000039522.58036.68
Backbone guided tabu search for solving the UBQP problem, Journal of Heuristics, vol.158, issue.2, pp.679-695, 2013. ,
DOI : 10.1007/s10732-011-9164-4
Probabilistic GRASP-Tabu Search algorithms for the UBQP problem, Computers & Operations Research, vol.40, issue.12, pp.3100-3107, 2013. ,
DOI : 10.1016/j.cor.2011.12.006
Path relinking for unconstrained binary quadratic programming, European Journal of Operational Research, vol.223, issue.3, pp.595-604, 2012. ,
DOI : 10.1016/j.ejor.2012.07.012
An Evolutionary Algorithm for the Unconstrained Binary Quadratic Problems, of Advances in Soft Computing, pp.3-16, 2005. ,
DOI : 10.1007/3-540-31182-3_1
An evolutionary heuristic for quadratic 0???1 programming, European Journal of Operational Research, vol.119, issue.3, pp.662-670, 1999. ,
DOI : 10.1016/S0377-2217(98)00359-2
A hybrid metaheuristic approach to solving the UBQP problem, European Journal of Operational Research, vol.207, issue.3, pp.1254-1262, 2010. ,
DOI : 10.1016/j.ejor.2010.06.039
Memetic algorithms for the unconstrained binary quadratic programming problem, Biosystems, vol.78, issue.1-3, pp.99-118, 2004. ,
DOI : 10.1016/j.biosystems.2004.08.002
Solving the minimum sum coloring problem via binary quadratic programming ,
Some Considerations about Computational Complexity for Multi Objective Combinatorial Problems, Lecture Notes in Economics and Mathematical Systems, vol.294, pp.222-232, 1987. ,
DOI : 10.1007/978-3-642-46618-2_15
Multicriteria optimization, 2005. ,
DOI : 10.1007/978-3-662-22199-0
Performance assessment of multiobjective optimizers: an analysis and review, IEEE Transactions on Evolutionary Computation, vol.7, issue.2, pp.117-132, 2003. ,
DOI : 10.1109/TEVC.2003.810758
A tutorial on the performance assessment of stochastic multiobjective optimizers, TIK Report, vol.214, 2006. ,
Van Veldhuizen, Evolutionary Algorithms for Solving Multi-Objective Problems, 2007. ,
Multiobjective Combinatorial Optimization ??? Theory, Methodology, and Applications, of International Series in Operations Research & Management Science, pp.369-444, 2003. ,
DOI : 10.1007/0-306-48107-3_8
Solving efficiently the 0???1 multi-objective knapsack problem, Computers & Operations Research, vol.36, issue.1, pp.260-279, 2009. ,
DOI : 10.1016/j.cor.2007.09.009
Assessing solution quality of biobjective 0-1 knapsack problem using evolutionary and heuristic algorithms, Applied Soft Computing, vol.10, issue.3, pp.711-718, 2010. ,
DOI : 10.1016/j.asoc.2009.08.037
Approximation algorithms for the bi-criteria weighted MAX-CUT problem, Discrete Applied Mathematics, vol.154, issue.12, pp.1685-1692, 2006. ,
DOI : 10.1016/j.dam.2006.02.008
URL : https://hal.archives-ouvertes.fr/hal-00341348
Instance Generators and Test Suites for the Multiobjective Quadratic Assignment Problem, 2nd International Conference on Evolutionary Multi-Criterion Optimization (EMO 2003), pp.295-310, 2003. ,
DOI : 10.1007/3-540-36970-8_21
A study of stochastic local search algorithms for the biobjective QAP with correlated flow matrices, European Journal of Operational Research, vol.169, issue.3, pp.943-959, 2006. ,
DOI : 10.1016/j.ejor.2004.08.024
OR-Library: Distributing Test Problems by Electronic Mail, Journal of the Operational Research Society, vol.41, issue.11, pp.1069-1072, 1990. ,
DOI : 10.1057/jors.1990.166
On the structure of multiobjective combinatorial search space: MNK-landscapes with correlated objectives, European Journal of Operational Research, vol.227, issue.2, pp.331-342, 2013. ,
DOI : 10.1016/j.ejor.2012.12.019
URL : https://hal.archives-ouvertes.fr/hal-00760097
Hybrid metaheuristics in combinatorial optimization: A survey, Applied Soft Computing, vol.11, issue.6, pp.4135-4151, 2011. ,
DOI : 10.1016/j.asoc.2011.02.032
URL : https://hal.archives-ouvertes.fr/hal-01224683
Memetic Algorithms in Discrete Optimization, Studies in Computational Intelligence, vol.379, issue.6, pp.73-94, 2012. ,
DOI : 10.1007/978-3-642-23247-3_6
Memetic algorithms for multiobjective optimization: Issues, methods and prospects, in: Recent Advances in Memetic Algorithms, of Studies in Fuzziness and Soft Computing, pp.313-352, 2005. ,
Application and comparison of hybrid evolutionary multiobjective optimization algorithms for solving task scheduling problem on heterogeneous systems, Applied Soft Computing, vol.11, issue.2, pp.2725-2734, 2011. ,
DOI : 10.1016/j.asoc.2010.11.003
The Use of Reference Objectives in Multiobjective Optimization, Lecture Notes in Economics and Mathematical Systems, vol.177, pp.468-486, 1980. ,
DOI : 10.1007/978-3-642-48782-8_32
Multiple Criteria Optimization: Theory, Computation and Application, 1986. ,
Application of multiple criteria evolutionary algorithms to vector optimisation, decision support and reference point approaches, Journal of Telecommunications and Information Technology, vol.3, pp.16-33, 2003. ,
A Preference-Based Evolutionary Algorithm for Multi-Objective Optimization, Evolutionary Computation, vol.17, issue.3, pp.411-436, 2009. ,
DOI : 10.1162/106365600568202
A parallel multiple reference point approach for multi-objective optimization, European Journal of Operational Research, vol.205, issue.2, pp.390-400, 2010. ,
DOI : 10.1016/j.ejor.2009.12.027
URL : https://hal.archives-ouvertes.fr/hal-00522619
Efficient evaluations for solving large 0-1 unconstrained quadratic optimisation problems, International Journal of Metaheuristics, vol.1, issue.1, pp.3-10, 2010. ,
DOI : 10.1504/IJMHEUR.2010.033120
A fast and elitist multiobjective genetic algorithm: NSGA-II, IEEE Transactions on Evolutionary Computation, vol.6, issue.2, pp.182-197, 2002. ,
DOI : 10.1109/4235.996017
From fitness landscape analysis to efficient local search algorithms, Journal of Heuristics, pp.10-1007 ,
URL : https://hal.archives-ouvertes.fr/hal-00832029
A software framework based on a conceptual unified model for evolutionary multiobjective optimization: ParadisEO-MOEO, European Journal of Operational Research, vol.209, issue.2, pp.104-112, 2011. ,
DOI : 10.1016/j.ejor.2010.07.023
URL : https://hal.archives-ouvertes.fr/hal-00522612
Set-based multiobjective fitness landscapes, Proceedings of the 13th annual conference on Genetic and evolutionary computation, GECCO '11, pp.769-776, 2011. ,
DOI : 10.1145/2001576.2001681
URL : https://hal.archives-ouvertes.fr/hal-00460442
