On reduced-order interval observers for time-delay systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The estimation problem for uncertain time-delay systems is addressed. A design method of reduced-order interval observers is proposed. The observer estimates the set of admissi-ble values (the interval) for the state at each instant of time. The cases of known fixed delays and uncertain time-varying delays are analyzed. The proposed approach can be applied to linear delay systems and nonlinear time-delay systems in the output canonical form. The framework efficiency is demonstrated on examples of nonlinear systems.
Delay_interval_observer.pdf (407.09 Ko) Télécharger le fichier
hal-00801809 , version 1 (18-03-2013)
  • HAL Id : hal-00801809 , version 1
Denis Efimov, Wilfrid Perruquetti, Jean-Pierre Richard. On reduced-order interval observers for time-delay systems. European Control Conference 2013, Jul 2013, Zurich, Switzerland. ⟨hal-00801809⟩
194 Consultations
262 Téléchargements
