Flow in multi-scale fracture networks: numerical optimization by use of a Mortar-like method. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Jean-Raynald de Dreuzy
Philippe Davy
We study flow in fractured media. We propose to decouple flow problem between fractures and the mesh generation by using a Mortar-like method at the intersections between fractures. Fractures can be meshed independently and the Mortar-like method solves flow on non-matching meshes. From a technical point of view, the method offers a tractable solution for the geometrical configuration leading to flat meshes. From the more general point of view of permeability upscaling, the method leads to several optimization possibilities for simulating flow on several orders of magnitude. We describe the details of the method, its performances, optimization possibilities and applications.
Fichier non déposé
hal-00801867 , version 1 (18-03-2013)
  • HAL Id : hal-00801867 , version 1
Géraldine Pichot, Jean-Raynald de Dreuzy, Jocelyne Erhel, Philippe Davy. Flow in multi-scale fracture networks: numerical optimization by use of a Mortar-like method.. MAMERN'2009, University of Pau and C.N.R.S, France University of Granada, Spain University Mohammed I - Oujda, Morocco, Jun 2009, Pau, France. pp.761-766. ⟨hal-00801867⟩
583 Consultations
0 Téléchargements
