Repseek, a tool to retrieve approximate repeats from large DNA sequences, Bioinformatics, vol.23, issue.1, pp.119-121, 2007. ,
DOI : 10.1093/bioinformatics/btl519
VARUN: Discovering Extensible Motifs under Saturation Constraints, IEEE/ACM Transactions on Computational Biology and Bioinformatics, vol.7, issue.4, pp.752-762, 2010. ,
DOI : 10.1109/TCBB.2008.123
LAGAN and Multi-LAGAN: Efficient Tools for Large-Scale Multiple Alignment of Genomic DNA, Genome Research, vol.13, issue.4, pp.721-731, 2003. ,
DOI : 10.1101/gr.926603
Inferring mobile elements in S.cerevisiae strains, Proceedings of International Conference on Bioinformatics Models, pp.131-136, 2011. ,
Efficient Bubble Enumeration in Directed Graphs, Proceedings of 19th Symposium on String Processing and Information Retrieval, pp.118-129 ,
DOI : 10.1007/978-3-642-34109-0_13
Algorithm 457: finding all cliques of an undirected graph, Communications of the ACM, vol.16, issue.9, pp.575-577, 1973. ,
DOI : 10.1145/362342.362367
Vingron, q-gram based database searching using a suffix array (QUASAR), ACM Conference on Research in Computational Molecular Biology, pp.77-83, 1999. ,
DOI : 10.1145/299432.299460
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.42.3803
MUSCLE: multiple sequence alignment with high accuracy and high throughput, Nucleic Acids Research, vol.32, issue.5, pp.1792-1797, 2004. ,
DOI : 10.1093/nar/gkh340
URL : http://www.ncbi.nlm.nih.gov/pmc/articles/PMC390337
An optimized filter for finding multiple repeats in DNA sequences, ACS/IEEE International Conference on Computer Systems and Applications, AICCSA 2010, pp.1-8, 2010. ,
DOI : 10.1109/AICCSA.2010.5587026
URL : https://hal.archives-ouvertes.fr/inria-00480001
Finding long and multiple repetitions with edit distance, Proceedings of the Prague Stringology Conference, 2011. ,
MADMX: A Strategy for Maximal Dense Motif Extraction, Journal of Computational Biology, vol.18, issue.4, pp.535-545, 2011. ,
DOI : 10.1089/cmb.2010.0177
A FIRST APPROACH TO FINDING COMMON MOTIFS WITH GAPS, International Journal of Foundations of Computer Science, vol.11, issue.06, pp.1145-1154, 2005. ,
DOI : 10.1142/S0129054105003716
URL : https://hal.archives-ouvertes.fr/hal-00620030
The taming of a transposon: V(D)J recombination and the immune system, Immunological Reviews, vol.91, issue.1, pp.233-248, 2004. ,
DOI : 10.1146/annurev.cellbio.15.1.435
Enumerating all connected maximal common subgraphs in two graphs, Theoretical Computer Science, vol.250, issue.1-2, pp.1-30, 2001. ,
DOI : 10.1016/S0304-3975(00)00286-3
URL : http://doi.org/10.1016/s0304-3975(00)00286-3
Kalign2: high-performance multiple alignment of protein and nucleotide sequences allowing external features, Nucleic Acids Research, vol.37, issue.3, pp.858-865, 2009. ,
DOI : 10.1093/nar/gkn1006
Kalign ? an accurate and fast multiple sequence alignment algorithm, BMC Bioinformatics, vol.6, pp.1-20, 2005. ,
DOI : 10.1093/nar/gkl191
URL : http://doi.org/10.1093/nar/gkl191
A tool for multiple sequence alignment., Proc. Nat. Acad. Sci, pp.4412-4415, 1989. ,
DOI : 10.1073/pnas.86.12.4412
URL : https://www.ncbi.nlm.nih.gov/pmc/articles/PMC287279/pdf
Population genomics of domestic and wild yeasts, Nature, vol.26, issue.7236, pp.337-341, 2009. ,
DOI : 10.1099/00207713-50-5-1931
URL : http://www.ncbi.nlm.nih.gov/pmc/articles/PMC2659681
Algorithms for Extracting Structured Motifs Using a Suffix Tree with an Application to Promoter and Regulatory Site Consensus Identification, Journal of Computational Biology, vol.7, issue.3-4, pp.3-4, 2000. ,
DOI : 10.1089/106652700750050826
T-coffee: a novel method for fast and accurate multiple sequence alignment 1 1Edited by J. Thornton, Journal of Molecular Biology, vol.302, issue.1, pp.205-217, 2000. ,
DOI : 10.1006/jmbi.2000.4042
The Effect of Transposable Element Insertions on Gene Expression Evolution in Rodents, PLoS ONE, vol.35, issue.2, p.4321, 2009. ,
DOI : 10.1371/journal.pone.0004321.s004
Lossless filter for multiple repetitions with Hamming distance, Journal of Discrete Algorithms, vol.6, issue.3, pp.497-509, 2008. ,
DOI : 10.1016/j.jda.2007.03.003
URL : https://hal.archives-ouvertes.fr/inria-00179731
Lossless Filter for Finding Long Multiple Approximate Repetitions Using a New Data Structure, the Bi-factor Array, Proceedings of 12th Symposium on String Processing and Information Retrieval, pp.179-190, 2005. ,
DOI : 10.1007/11575832_20
URL : https://hal.archives-ouvertes.fr/inria-00328129
Lossless filter for multiple repeats with bounded edit distance, Algorithms for Molecular Biology, vol.4, issue.1, pp.1-20, 2009. ,
DOI : 10.1186/1748-7188-4-3
URL : https://hal.archives-ouvertes.fr/hal-00784457
Identifying SNPs without a Reference Genome by Comparing Raw Reads, Proceedings of 17th Symposium on String Processing and Information Retrieval, pp.147-158, 2010. ,
DOI : 10.1007/978-3-642-16321-0_14
URL : https://hal.archives-ouvertes.fr/inria-00514887
Filters and Seeds Approaches for Fast Homology Searches in Large Datasets, Algorithms in Computational Molecular Biology, pp.299-320, 2010. ,
DOI : 10.1016/0304-3975(92)90143-4
URL : https://hal.archives-ouvertes.fr/inria-00425370
-Matches over a Given Length, Journal of Computational Biology, vol.13, issue.2, pp.296-308, 2006. ,
DOI : 10.1089/cmb.2006.13.296
URL : https://hal.archives-ouvertes.fr/hal-00307305
Extracting string motif bases for quorum higher than two, Theoretical Computer Science, vol.460, pp.94-103, 2012. ,
DOI : 10.1016/j.tcs.2012.06.021
DIALIGN-TX: greedy and progressive approaches for segment-based multiple sequence alignment, Algorithms for Molecular Biology, vol.3, issue.1, 2008. ,
DOI : 10.1186/1748-7188-3-6
URL : http://doi.org/10.1186/1748-7188-3-6
CLUSTAL W: improving the sensitivity of progressive multiple sequence alignment through sequence weighting, position-specific gap penalties and weight matrix choice, Nucleic Acids Research, vol.22, issue.22, pp.4673-4680, 1994. ,
DOI : 10.1093/nar/22.22.4673
Repetitive DNA and next-generation sequencing: computational challenges and solutions, Nature Reviews Genetics, vol.18, pp.36-46, 2012. ,
DOI : 10.1093/dnares/dsq028
URL : https://www.ncbi.nlm.nih.gov/pmc/articles/PMC3324860/pdf
LTR_FINDER: an efficient tool for the prediction of full-length LTR retrotransposons, Nucleic Acids Research, vol.35, issue.Web Server, pp.265-268, 2007. ,
DOI : 10.1093/nar/gkm286
