A new descriptor for 2D depth image indexing and 3D model retrieval - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
We present here a new descriptor for depth images adapted to 2D/3D model matching and retrieving. We propose a representation of a 3D model by 20 depth images rendered from the vertices of a regular dodecahedron. One depth image of a 3D model is associated to a set of depth lines which will be afterward transformed into sequences. The depth sequence information provides a more accurate description of 3D shape boundaries than using other 2D shape descriptors. Similarity computing is performed when dynamic programming distance (DPD) is used to compare the depth line descriptors. The DPD leads to an accurate matching of sequences even in the presence of local shifting on the shape. Results on a large 3D database show efficiency of our 2D/3D approach.
chaouchverroustblondeticip07.pdf (311.94 Ko) Télécharger le fichier
hal-00802581 , version 1 (20-03-2013)
Mohamed Chaouch, Anne Verroust-Blondet. A new descriptor for 2D depth image indexing and 3D model retrieval. ICIP 2007 - International Conference on Image Processing, Sep 2007, San Antonio, United States. pp.VI - 373 - VI - 376, ⟨10.1109/ICME.2007.4284721⟩. ⟨hal-00802581⟩
Collections
INRIA INRIA2
162 Consultations
348 Téléchargements
