Complexity of Delaunay triangulation for points on lower-dimensional polyhedra, Proc. 18th ACM-SIAM Sympos. Discrete Algorithms, pp.1106-1113, 2007. ,
URL : https://hal.archives-ouvertes.fr/inria-00182835
A simple entropy-based algorithm for planar point location, ACM Transactions on Algorithms, vol.3, issue.2, p.17, 2007. ,
DOI : 10.1145/1240233.1240240
A Linear Bound on the Complexity of the Delaunay Triangulation of Points on Polyhedral Surfaces, Discrete and Computational Geometry, vol.31, issue.3, pp.369-384, 2004. ,
DOI : 10.1007/s00454-003-2870-4
URL : https://hal.archives-ouvertes.fr/inria-00072135
Complexity of the delaunay triangulation of points on surfaces the smooth case, Proceedings of the nineteenth conference on Computational geometry , SCG '03, pp.237-246, 2003. ,
DOI : 10.1145/777792.777823
The shortest path through many points, Math. Proc. Camb, pp.299-327, 1959. ,
DOI : 10.2307/2031707
On the stabbing number of a random Delaunay triangulation, Computational Geometry, vol.36, issue.2, pp.89-105, 2007. ,
DOI : 10.1016/j.comgeo.2006.05.005
Computing Dirichlet tessellations, The Computer Journal, vol.24, issue.2, pp.162-166, 1981. ,
DOI : 10.1093/comjnl/24.2.162
CGAL User and Reference Manual, 3.6 edition, 2010. ,
Point location in well-shaped meshes using jump-and-walk, Proc. CCCG'11, pp.147-152, 2011. ,
On the asymptotic growth rate of some spanning trees embedded in, Operations Research Letters, vol.39, issue.1, pp.44-48, 2011. ,
DOI : 10.1016/j.orl.2010.10.005
A pedagogic JavaScript program for point location strategies. Demo, Proc. 27th Annu. Symp. Comp. Geom, pp.295-296, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00850551
Spatial sorting, CGAL User and Reference Manual. 3.6 edition, 2010. ,
The Open Problems Project ,
Proximate point searching, Computational Geometry, vol.28, issue.1, pp.29-40, 2004. ,
DOI : 10.1016/j.comgeo.2004.01.005
THE DELAUNAY HIERARCHY, International Journal of Foundations of Computer Science, vol.13, issue.02, pp.163-180, 2002. ,
DOI : 10.1142/S0129054102001035
URL : https://hal.archives-ouvertes.fr/inria-00166711
WALKING IN A TRIANGULATION, International Journal of Foundations of Computer Science, vol.13, issue.02, pp.181-199, 2002. ,
DOI : 10.1142/S0129054102001047
URL : https://hal.archives-ouvertes.fr/inria-00344519
Expected time analysis for Delaunay point location, Computational Geometry, vol.29, issue.2, pp.61-89, 2004. ,
DOI : 10.1016/j.comgeo.2004.02.002
A Note on Point Location in Delaunay Triangulations of Random Points, Algorithmica, vol.22, issue.4, pp.477-482, 1998. ,
DOI : 10.1007/PL00009234
Convex hulls of samples from spherically symmetric distributions, Discrete Applied Mathematics, vol.31, issue.2, pp.113-132, 1991. ,
DOI : 10.1016/0166-218X(91)90064-4
Structural filtering: a paradigm for efficient and exact geometric programs, Proc. 11th Canadian Conf. on Comp. Geom, 1999. ,
DOI : 10.1016/j.comgeo.2004.12.007
General Spacefilling Curve Heuristics and Limit Theory for the Traveling Salesman Problem, Journal of Complexity, vol.10, issue.2, pp.230-245, 1994. ,
DOI : 10.1006/jcom.1994.1011
On the average complexity of 3D-Voronoi diagrams of random points on convex polytopes, Computational Geometry, vol.25, issue.3, pp.197-231, 2003. ,
DOI : 10.1016/S0925-7721(02)00123-2
Computing Dirichlet Tessellations in the Plane, The Computer Journal, vol.21, issue.2, pp.168-173, 1978. ,
DOI : 10.1093/comjnl/21.2.168
An experimental study of point location in planar arrangements in CGAL, Journal of Experimental Algorithmics, vol.13, pp.2-3, 2009. ,
DOI : 10.1145/1412228.1412237
Improved Upper Bounds for Pairing Heaps, Proc. 7th Scandinavian Workshop on Algorithm Theor, pp.32-45, 2000. ,
DOI : 10.1007/3-540-44985-X_5
Proximate planar point location, Proceedings of the nineteenth conference on Computational geometry , SCG '03, pp.220-226, 2003. ,
DOI : 10.1145/777792.777826
Expected asymptotically optimal planar point location, Computational Geometry, vol.29, issue.1, pp.19-22, 2004. ,
DOI : 10.1016/j.comgeo.2004.03.010
A static optimality transformation with applications to planar point location, Proc. 27th Annu. Symp. Comp. Geom, pp.21-26, 2011. ,
Poisson surface reconstruction, Proc. 4th Eurographics Symp. on Geom. Processing, pp.61-70, 2006. ,
Classroom Examples of Robustness Problems in Geometric Computations, Proc. 12th European Symp. on Algorithms, pp.702-713, 2004. ,
DOI : 10.1007/978-3-540-30140-0_62
URL : https://hal.archives-ouvertes.fr/inria-00344515
Optimal Search in Planar Subdivisions, SIAM Journal on Computing, vol.12, issue.1, pp.28-35, 1983. ,
DOI : 10.1137/0212002
Optimum binary search trees, Acta Informatica, vol.6, issue.1, pp.14-25, 1971. ,
DOI : 10.1007/BF00264289
Lower bounds for expected-case planar point location, Computational Geometry, vol.39, issue.2, pp.91-103, 2008. ,
DOI : 10.1016/j.comgeo.2007.06.001
Fast randomized point location without preprocessing in two-and threedimensional Delaunay triangulations, Proc. 12th Annu. Sympos, pp.274-283, 1996. ,
3D triangulations, 2010. ,
Spacefilling curves and the planar travelling salesman problem, Journal of the ACM, vol.36, issue.4, pp.719-737, 1989. ,
DOI : 10.1145/76359.76361
Integral Geometry and Geometric Probability, 1976. ,
Stabbing Delaunay Tetrahedralizations, Discrete & Computational Geometry, vol.32, issue.3, p.343, 2002. ,
DOI : 10.1007/s00454-004-1095-5
The Algorithm Design Manual, 2008. ,
Cost of sequential connection for points in space, Operations Research Letters, vol.8, issue.3, pp.137-142, 1989. ,
DOI : 10.1016/0167-6377(89)90039-4
Worst-Case Growth Rates of Some Classical Problems of Combinatorial Optimization, SIAM Journal on Computing, vol.18, issue.2, pp.278-287, 1989. ,
DOI : 10.1137/0218019
THE EXACT COMPUTATION PARADIGM, Computing in Euclidean Geometry, pp.452-492, 1995. ,
DOI : 10.1142/9789812831699_0011
2D triangulations, CGAL User and Reference Manual. 3.6 edition, 2010. ,
Adaptive Point Location with almost No Preprocessing in Delaunay Triangulations, 2012 Ninth International Symposium on Voronoi Diagrams in Science and Engineering, pp.84-89, 2012. ,
DOI : 10.1109/ISVD.2012.16
