Optimal sharing of bags of tasks in heterogeneous clusters, 15th ACM Symp. on Parallelism in Algorithms and Architectures (SPAA'03), p.110, 2003. ,
Ecient collective communication on heterogeneous networks of workstations, Proceedings of the 27th International Conference on Parallel Processing (ICPP'98) ,
Communication modeling of heterogeneous networks of workstations for performance characterization of collective operations ,
, HCW'99, the 8th Heterogeneous Computing Workshop, p.125133, 1999.
Message multicasting in heterogeneous networks, SIAM Journal on Computing, vol.30, issue.2, p.347358, 2000. ,
A realistic model and an ecient heuristic for scheduling with heterogeneous processors, HCW'2002, the 11th Heterogeneous Computing Workshop, 2002. ,
A polynomial-time algorithm for allocating independent tasks on heterogeneous fork-graphs ,
URL : https://hal.archives-ouvertes.fr/hal-00807403
, Seventeenth International Symposium On Computer and Information Sciences, p.115119, 2002.
The master-slave paradigm with heterogeneous processors ,
URL : https://hal.archives-ouvertes.fr/hal-00789429
, IEEE Trans. Parallel Distributed Systems, vol.14, issue.9, p.897908, 2003.
Ecient collective communication in distributed heterogeneous systems, Journal of Parallel and Distributed Computing, vol.63, p.251263, 2003. ,
Grid Computing: Making The Global Infrastructure a Reality ,
, , 2003.
, Scheduling Theory and its Applications, 1995.
Special issue on Recent Advances in Scheduling in Computer and manufacturing Systems, European Journal of Operational Research, vol.164, issue.3, p.690695, 2005. ,
Task scheduling in multiprocessing systems, Computer, vol.28, issue.12, p.2737, 1995. ,
Computers and Intractability, a Guide to the Theory of NP-Completeness, 1979. ,
Scheduling problems in a practical allocation model, J. Combinatorial Optimization, vol.1, issue.2, p.129149, 1997. ,
Task allocation on a network of processors, IEEE Trans. Computers, vol.49, issue.12, p.13391353, 2000. ,
On broadcasting in heterogenous networks, Proceedings of the fteenth annual ACM-SIAM symposium on Discrete algorithms, p.10111020, 2004. ,
Optimization and approximation in deterministic sequencing and scheduling: a survey, Annals of Discrete Mathematics, vol.5, p.287326, 1979. ,
Minimizing mean owtime and makespan on master-slave systems, J. Parallel and Distributed Computing, vol.65, issue.7, p.843856, 2005. ,
Broadcast scheduling optimization for heterogeneous cluster systems, Journal of Algorithms, vol.42, issue.1, p.135152, 2002. ,
An n job, one machine sequencing algorithm for minimizing the number of late jobs, Management Science, vol.15, issue.1, 1968. ,
Models of machines and computation for mapping in multicomputers, ACM Computing Surveys, vol.25, issue.3, p.103117, 1993. ,
A new task mapping technique for communication-aware scheduling strategies, Workshop for Scheduling and Resource Management for Cluster Computing (ICPP'01), p.349354, 2001. ,
The impact of heterogeneity on master-slave on-line scheduling, 2005. ,
URL : https://hal.archives-ouvertes.fr/inria-00070286
O-line and on-line scheduling on heterogeneous master-slave platforms, 2005. ,
O-line and online scheduling on heterogeneous master-slave platforms, Proceedings of the 14th Euromicro Conference on Parallel, Distributed and Network based Processing, 2006. ,
On-line scheduling, Handbook of Scheduling: Algorithms, Models, and Performance Analysis, 2004. ,
Improving static scheduling using inter-task concurrency measures ,
, Workshop for Scheduling and Resource Management for Cluster Computing (ICPP'01), p.375381, 2001.
Understanding the behavior and performance of non-blocking communications in MPI, Proceedings of Euro-Par 2004: Parallel Processing, vol.3149, p.173182, 2004. ,
On line scheduling-a survey, On-Line Algorithms, vol.1442, 1998. ,
Scheduling and load balancing in parallel and distributed systems, 1995. ,
Multiprocessor scheduling of unit-time jobs with arbitrary release times and deadlines ,
, SIAM Journal on Computing, vol.12, issue.2, p.294299, 1983.
Communication contention in task scheduling, IEEE Trans. Parallel Distributed Systems, vol.16, issue.6, p.503515, 2004. ,
Minimizing the aplication execution time through scheduling of subtasks and communication trac in a heterogeneous computing system, IEEE Transactions on Parallel and Distributed Systems, vol.8, issue.8, p.857871, 1997. ,
