Comments on ''Design and performance evaluation of load distribution strategies for multiple loads on heterogeneous linear daisy chain networks'' - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Parallel and Distributed Computing Année : 2008
Min, Veeravalli, and Barlas have proposed strategies to minimize the overall execution time of one or several divisible loads on a heterogeneous linear network, using one or more installments. We show on a very simple example that their approach does not always produce a solution and that, when it does, the solution is often suboptimal. We also show how to find an optimal scheduling for any instance, once the number of installments per load is given. Finally, we formally prove that under a linear cost model an optimal schedule has an infinite number of installments. Therefore such a cost model should not be used to design practical multi-installment algorithms.
JPDC.pdf (420.71 Ko) Télécharger le fichier
hal-00803476 , version 1 (15-10-2019)
Matthieu Gallet, Yves Robert, Frédéric Vivien. Comments on ''Design and performance evaluation of load distribution strategies for multiple loads on heterogeneous linear daisy chain networks''. Journal of Parallel and Distributed Computing, 2008, 68 (7), pp.1021-1031. ⟨10.1016/j.jpdc.2007.12.002⟩. ⟨hal-00803476⟩
125 Consultations
68 Téléchargements
