Real-Time Importance Sampling of Dynamic Environment Maps - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We introduce a simple and effective technique for light-based importance sampling of dynamic environment maps based on the formalism of Multiple Importance Sampling (MIS). The core idea is to balance per pixel the number of samples selected on each cube map face according to a quick and conservative evaluation of the lighting contribution: this increases the number of effective samples. In order to be suitable for dynamically generated or captured HDR environment maps, everything is computed on-line for each frame without any global preprocessing. Our results illustrate that the low number of required samples combined with a full-GPU implementation lead to real-time performance with improved visual quality. Finally, we illustrate that our MIS formalism can be easily extended to other strategies such as BRDF importance sampling.
main.pdf (6.28 Mo) Télécharger le fichier
short1071.flv (47.53 Mo) Télécharger le fichier
supplemental.pdf (8.49 Mo) Télécharger le fichier
Format : Figure, Image
Format : Vidéo
Format : Autre
hal-00803998 , version 1 (04-06-2013)
Heqi Lu, Romain Pacanowski, Xavier Granier. Real-Time Importance Sampling of Dynamic Environment Maps. Eurographics 2013 - Short Papers, May 2013, Girona, Spain. pp.65-68, ⟨10.2312/conf/EG2013/short/065-068⟩. ⟨hal-00803998⟩
732 Consultations
2134 Téléchargements
