Knot Segmentation in Noisy 3D Images of Wood - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Resolving a 3D segmentation problem is a common challenge in the domain of digital medical imaging. In this work, we focus on another original application domain: the 3D images of wood stem. At first sight, the nature of wood image looks easier to segment than classical medical image. However, the presence in the wood of a wet area called sapwood remains an actual challenge to perform an efficient segmentation. This paper introduces a first general solution to perform knot segmentation on wood with sapwood. The main idea of this work is to exploit the simple geometric properties of wood through an original combination of discrete connected component extractions, 2D contour detection and dominant point detection. The final segmentation algorithm is very fast and allows to extract several geometrical knot features.
hal-00804070 , version 1 (24-03-2013)
Adrien Krähenbühl, Bertrand Kerautret, Isabelle Debled-Rennesson. Knot Segmentation in Noisy 3D Images of Wood. 17th IAPR International Conference on Discrete Geometry for Computer Imagery - 2013, Mar 2013, Sevilla, Spain. pp.383-394, ⟨10.1007/978-3-642-37067-0_33⟩. ⟨hal-00804070⟩
149 Consultations
0 Téléchargements
