Combining appearance and motion for face and gender recognition from videos, Pattern Recognition, vol.42, pp.2818-2827, 2009. ,
DOI : 10.1016/j.patcog.2009.02.011
Robust real-time face detection, International Journal of Computer Vision, vol.57, pp.137-154, 2004. ,
DOI : 10.1023/b:visi.0000013087.49260.fb
Fast and accurate sequential floating forward feature selection with the bayes classifier applied to speech emotion recognition, Signal Processing, vol.88, pp.2956-2970, 2008. ,
DOI : 10.1016/j.sigpro.2008.07.001
, IEEE Transactions, vol.20, pp.673-686, 1998.
A comparative study of texture measures with classification based on featured distributions, Pattern Recognition, vol.29, pp.51-59, 1996. ,
, Signal Processing, 2012.
Eigenfaces for recognition, Journal of Cognitive Neuroscience, vol.3, pp.71-86, 1991. ,
Discriminant analysis for recognition of human face images, Lecture Notes in Computer Science, vol.1206, pp.125-142, 1997. ,
Independent component analysis: algorithms and applications, Neural Networks, vol.13, pp.411-430, 2000. ,
Online nonnegative matrix factorization with robust stochastic approximation, Neural Networks and Learning Systems, pp.2012-2013 ,
Nenmf: An optimal gradient method for nonnegative matrix factorization, IEEE Transactions on, vol.60, pp.2882-2898, 2012. ,
Manifold regularized discriminative nonnegative matrix factorization with fast gradient descent, Image Processing, IEEE Transactions on, vol.20, pp.2030-2048, 2011. ,
Input variable selection for feature extraction in classification problems, Signal Processing, vol.92, pp.636-648, 2012. ,
Conditional mutual information based boosting for facial expression recognition, British Machine Vision Conference, vol.1, pp.399-408, 2005. ,
Pattern recognition using feature feedback: Application to face recognition, International Journal of Control, Automation and Systems, vol.8, pp.141-148, 2010. ,
DOI : 10.1007/s12555-010-0118-7
Analysis of facial expressions using pca on half and full faces, ICALIP 2008. International Conference on, pp.1379-1383, 2008. ,
Image ratio features for facial expression recognition application, Systems, Man, and Cybernetics, Part B: Cybernetics, IEEE Transactions on, vol.40, pp.779-788, 2010. ,
Comparison between geometry-based and gabor-wavelets-based facial expression recognition using multi-layer perceptron, in: Automatic Face and Gesture Recognition, Proceedings. Third IEEE International Conference on, pp.454-459, 1998. ,
Local appearance based face recognition method using block based steerable pyramid transform, Signal Processing, vol.91, pp.38-50, 2011. ,
The contribution of the upper and lower face in happy and sad facial expression classification, Vision Research, vol.50, pp.1814-1823, 2010. ,
Feature subset selection: A correlation based filter approach, 1997. ,
A probabilistic approach to feature selection-a filter solution, pp.319-327 ,
Very simple classification rules perform well on most commonly used datasets, Machine Learning, vol.11, pp.63-90, 1993. ,
Toward an affect-sensitive multimodal human-computer interaction, Proceedings of the IEEE, vol.91, pp.1370-1390, 2003. ,
DOI : 10.1109/jproc.2003.817122
URL : http://spiral.imperial.ac.uk/bitstream/10044/1/5690/1/Pantic-ProcIEEE03.pdf
Visual-context boosting for eye detection, Systems, Man, and Cybernetics, Part B: Cybernetics, vol.40, pp.1460-1467, 2010. ,
Automatic facial feature detection for facial expression recognition, pp.407-412 ,
URL : https://hal.archives-ouvertes.fr/hal-00812308
, The MPLab GENKI Database, GENKI-4K Subset, 2011.
Neural network-based face detection, Pattern Analysis and Machine Intelligence, IEEE Transactions, vol.20, pp.23-38, 1998. ,
Locating facial features with an extended active shape model, Computer Vision ECCV, vol.5305, pp.504-513, 2008. ,
A direct adaptive method for faster backpropagation learning: the rprop algorithm, IEEE International Conference on, vol.1, pp.586-591, 1993. ,
Automatic classification of single facial images, Pattern Analysis and Machine Intelligence, IEEE Transactions on, vol.21, pp.1357-1362, 1999. ,
The feret evaluation methodology for face-recognition algorithms, Pattern Analysis and Machine Intelligence, IEEE Transactions on, vol.22, pp.1090-1104, 2000. ,
Graph-preserving sparse nonnegative matrix factorization with application to facial expression recognition, Systems, Man, and Cybernetics, Part B: Cybernetics, IEEE Transactions on, vol.41, pp.38-52, 2011. ,
Facial expression recognition using fisher weight maps, 2004. ,
An analysis of facial expression recognition under partial facial image occlusion, Image and Vision Computing, vol.26, pp.1052-1067, 2008. ,
Projected gradient method for kernel discriminant nonnegative matrix factorization and the applications, Signal Processing, vol.90, pp.2150-2163, 2010. ,
