Linear algebra algorithms in a heterogeneous cluster of personal computers, HCW'2000, pp.147-159, 2000. ,
A proposal for a heterogeneous cluster ScaLAPACK (dense linear solvers), IEEE Trans. Computers, vol.50, issue.10, pp.1052-1070, 2001. ,
URL : https://hal.archives-ouvertes.fr/hal-00808287
Matrix multiplication on heterogeneous platforms, IEEE TPDS, vol.12, issue.10, pp.1033-1051, 2001. ,
URL : https://hal.archives-ouvertes.fr/hal-00808288
A dynamic load balancing method on a heterogeneous cluster of workstations, Informatica, vol.23, issue.1, pp.49-56, 1999. ,
, ScaLAPACK Users' Guide. SIAM, 1997.
Dynamic load balancing computation of pulses propagating in a nonlinear medium, The Journal of Supercomputing, vol.28, issue.3, pp.279-294, 2004. ,
New static scheduling and elastic load balancing methods for parallel query processing, BIWIT, 1995. ,
High Performance Cluster Computing, vol.1, 1999. ,
Block data decomposition for data-parallel programming on a heterogeneous workstation network, HPDC, pp.42-49, 1993. ,
Dynamic load balancing in parallel discrete event simulation for spatially explicit problems, PADS'98, pp.46-53, 1998. ,
Scheduling blockcyclic array redistribution, IEEE TPDS, vol.9, issue.2, pp.192-205, 1998. ,
URL : https://hal.archives-ouvertes.fr/hal-00856854
Parallel structures and dynamic load balancing for adaptive finite element computation, Applied Numerical Mathematics, vol.26, issue.1-2, pp.241-263, 1997. ,
Adaptive local refinement with octree load balancing for the parallel solution of three-dimensional conservation laws, J. Parallel and Distributed Computing, vol.47, issue.2, pp.139-152, 1997. ,
A framework for integrating data alignment, distribution, and redistribution in distributed memory multiprocessors, IEEE TPDS, vol.12, issue.4, pp.416-431, 2001. ,
Dynamic load balancing of data parallel applications on a distributed network, ICS'95, pp.170-179, 1995. ,
A generalized processor mapping technique for array redistribution, IEEE TPDS, vol.12, issue.7, pp.743-757, 2001. ,
Load balancing for unstructured mesh applications, Parallel and Distributed Computing Practices, vol.2, 1999. ,
Array decomposition for nonuniform computational environments, Journal of Parallel and Distributed Computing, vol.36, pp.91-105, 1996. ,
Processor mapping techniques towards efficient data redistribution, IEEE TPDS, vol.6, issue.12, pp.1234-1247, 1995. ,
Distribution assignment placement: effective optimization of redistribution costs, IEEE TPDS, vol.13, issue.6, pp.628-647, 2002. ,
The High Performance Fortran Handbook, 1994. ,
NP-Completeness of dynamic remapping, Proceedings of the Fourth Workshop on Compilers for Parallel Computers, 1993. ,
Dynamic load balancing of samr applications on distributed systems, Proceedings of SC'01, 2001. ,
Parallel image processing applications on a network of workstations, Parallel Computing, vol.21, pp.137-160, 1995. ,
Elastic load balancing for image processing algorithms, Parallel Computation, vol.591, pp.438-451, 1992. ,
URL : https://hal.archives-ouvertes.fr/hal-00857073
Optimal dynamic remapping of data parallel computations, IEEE Trans. Computers, vol.39, issue.2, pp.206-219, 1990. ,
Dynamic remapping of parallel computations with varying resource demands, IEEE Trans. Computers, vol.37, issue.9, pp.1073-1087, 1988. ,
A framework for integrating data alignment, distribution, and redistribution in distributed memory multiprocessors, IEEE TPDS, vol.10, issue.12, pp.1217-1240, 1999. ,
Fast runtime block-cyclic data redistribution on multiprocessors, J. Parallel Distributed Computing, vol.45, pp.63-72, 1997. ,
Data redistribution algorithms for homogeneous and heterogeneous processor rings, INRIA, 2004. ,
Data redistribution algorithms for homogeneous and heterogeneous processor rings, HiPC, vol.3296, pp.123-132, 2004. ,
URL : https://hal.archives-ouvertes.fr/hal-00807283
ARAMIS: a remote access medical imaging system, ISCOPE'99, vol.1732, 1999. ,
Multilevel diffusion schemes for repartitioning of adaptive meshes, Journal of Parallel and Distributed Computing, vol.47, pp.109-124, 1997. ,
A unified algorithm for load-balancing adaptive scientific simulations, Proceedings of SC'00, 2000. ,
Scheduling and load balancing in parallel and distributed systems, 1995. ,
Efficient algorithms for array redistribution, IEEE TPDS, vol.7, issue.6, pp.587-594, 1996. ,
A practical approach to dynamic load balancing, IEEE TPDS, vol.9, issue.93, pp.235-248, 1998. ,
On runtime parallel scheduling for processor load balancing, IEEE TPDS, vol.8, issue.2, pp.173-186, 1997. ,
