New interface
Conference papers
A Control of Smooth Deformations with Topological Change on Polyhedral Mesh Based on Curves and Loops
Abstract : We propose a method to model and control topological changes by a smooth defonnation of a polyhedral mesh using curves and loops. As changing the genus of a surface is not a continuous transformation, the topological change is made when an intermediate shape between the two topologies has been obtained. The creation and the deletion of holes are studied. The deletion of a hole uses non null-homotopic loops to designate the hole to be deleted. A method computing two independent loops associated to a hole is presented.
Document type :
Conference papers
Complete list of metadata
Cited literature [24 references]  Display  Hide  Download
https://hal.inria.fr/hal-00804677
Contributor : Anne Verroust-Blondet Connect in order to contact the contributor
Submitted on : Wednesday, May 22, 2013 - 1:46:57 PM
Last modification on : Friday, February 4, 2022 - 3:23:42 AM
Long-term archiving on: : Friday, August 23, 2013 - 2:45:13 AM
File
smi2002.pdf
Identifiers
Collections
Citation
Anne Verroust, Matthieu Finiasz. A Control of Smooth Deformations with Topological Change on Polyhedral Mesh Based on Curves and Loops. International Conference on Shape Modeling and Applications 2002 (SMI'02), May 2002, Banff, Canada. ⟨10.1109/SMA.2002.1003545⟩. ⟨hal-00804677⟩
Share
Metrics
Record views
99
Files downloads
116
