MRI lesion profiles in sporadic Creutzfeldt-Jakob disease. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Neurology Année : 2009
B. Meissner
  • Fonction : Auteur
K. Kallenberg
  • Fonction : Auteur
P. Sanchez-Juan
  • Fonction : Auteur
D. Collie
  • Fonction : Auteur
S. Almonti
  • Fonction : Auteur
S. J. Collins
  • Fonction : Auteur
P. Smith
  • Fonction : Auteur
P. Cras
  • Fonction : Auteur
G. H. Jansen
  • Fonction : Auteur
M. B. Coulthart
  • Fonction : Auteur
H. Roberts
  • Fonction : Auteur
B. van Everbroeck
  • Fonction : Auteur
V. Mellina
  • Fonction : Auteur
R. G. Will
  • Fonction : Auteur
I. Zerr
  • Fonction : Auteur
BACKGROUND: With respect to sporadic Creutzfeldt-Jakob disease (sCJD), six molecular subtypes (MM1, MM2, MV1, MV2, VV1, and VV2) have been described, which vary with respect to age at disease onset, disease duration, early symptoms, and neuropathology. MRI signal alterations were reported to correlate with distinct Creutzfeldt-Jakob disease (CJD) subtypes. This multicenter, international study aimed to describe the brain MRI findings associated with each of the sCJD molecular subtypes. METHODS: Pathologically confirmed sCJD cases with codon 129 genotype (MM, MV, and VV), PrP(Sc) type, and fluid-attenuated inversion recovery (FLAIR) or diffusion-weighted imaging (DWI) were collected in seven countries. All MRI scans were assessed for signal changes according to a standard protocol encompassing seven cortical regions, basal ganglia, thalamus, and cerebellum. RESULTS: MRI scans were evaluated in 211 CJD patients (98 MM1, 23 MM2, 19 MV1, 30 MV2, 9 VV1, and 32 VV2). Basal ganglia hyperintensities occurred most frequently in MV2, VV2, and MM1 subtypes (79, 77, and 70%). Wide cerebral cortical signal increase was most common in VV1, MM2, and MV1 subtypes (86, 77, and 77%). Thalamic hyperintensities occurred most often in VV2 (45%) and MV2 (43%). The most consistent finding across most subtypes was high signal in basal ganglia, with these abnormalities found in 63% (FLAIR) and 71% (DWI). CONCLUSION: Cortical signal increase and hyperintensities in the basal ganglia and thalamus are detected by MRI across all molecular sporadic Creutzfeldt-Jakob disease subtypes. Our findings argue that characteristic MRI lesion patterns may occur for each molecular subtype.
Fichier non déposé
hal-00805400 , version 1 (27-03-2013)
B. Meissner, K. Kallenberg, P. Sanchez-Juan, D. Collie, D. M. Summers, et al.. MRI lesion profiles in sporadic Creutzfeldt-Jakob disease.. Neurology, 2009, 72 (23), pp.1994-2001. ⟨10.1212/WNL.0b013e3181a96e5d⟩. ⟨hal-00805400⟩
42 Consultations
0 Téléchargements
