Gait and balance disorders in Parkinson's disease: impaired active braking of the fall of centre of gravity. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Movement Disorders Année : 2009
Gait and balance disorders are common in Parkinson's disease (PD), but its pathophysiology is still poorly understood. Step length, antero-posterior, and vertical velocities of the center of gravity (CG) during gait initiation were analyzed in 32 controls and 32 PD patients, with and without levodopa, using a force platform. Brain volumes and mesencephalic surface area were measured in PD patients. During the swing limb period, controls showed a fall in the CG, which was reversed before foot-contact indicating active braking of the CG fall. In PD patients, without levodopa, step length and velocity were significantly reduced and no braking occurred before foot-contact in 22 patients. With levodopa, step length and velocity increased in all patients and 7 patients improved their braking capacity. PD patients with normal braking (n = 17) had significantly lower gait and balance disorder scores and higher normalized-mesencephalic surface areas compared to patients with impaired braking (n = 15). The decreased step length and velocity, characteristic of PD, mainly result from degeneration of central dopaminergic systems. The markedly decreased braking capacity observed in half the PD patients contributes to their gait disorders and postural instability, perhaps as a result of nondopaminergic lesions, possibly at the mesencephalic level.
hal-00805424 , version 1 (27-03-2013)
Nathalie Chastan, Manh Cuong Do, Fabrice Bonneville, Frédéric Torny, Frédéric Bloch, et al.. Gait and balance disorders in Parkinson's disease: impaired active braking of the fall of centre of gravity.. Movement Disorders, 2009, 24 (2), pp.188-95. ⟨10.1002/mds.22269⟩. ⟨hal-00805424⟩
257 Consultations
0 Téléchargements
