Effects of nigral stimulation on locomotion and postural stability in patients with Parkinson's disease. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Brain - A Journal of Neurology Année : 2009
The physiopathology of gait and balance disorders in Parkinson's disease patients is still poorly understood. Levodopa treatment and subthalamic nucleus (STN) stimulation improve step length and walking speed, with less effect on postural instability. These disorders have been linked to dysfunction of the descending basal ganglia outputs to brainstem structures. In this study, we evaluated the effects of stimulation of the substantia nigra pars reticulata (SNr), on locomotion and balance in Parkinson's disease patients. Biomechanical parameters and leg muscle activity were recorded during gait initiation in seven selected patients operated for bilateral STN stimulation, out of 204 stimulated patients, with one contact of each electrode located within the SNr. Step length, anteroposterior and vertical velocities of the centre of gravity were studied, with special reference to the subjects' ability to brake the centre of gravity fall before foot-contact, and compared to seven controls. In Parkinson's disease patients, five treatment conditions were tested: (i) no treatment, (ii) levodopa treatment, (iii) STN stimulation, (iv) SNr stimulation and (v) combined levodopa treatment and STN stimulation. The effects of these treatments on motor parkinsonian disability were assessed with the UPDRS III scale, separated into 'axial' (rising from chair, posture, postural stability and gait) and 'distal' scores. Whereas levodopa and/or STN stimulation improved 'axial' and 'distal' motor symptoms, SNr stimulation improved only the 'axial' symptoms. Compared to controls, untreated Parkinson's disease patients showed reduced step length and velocity, and poor braking just prior to foot-contact, with a decrease in both soleus (S) and anterior tibialis (AT) muscle activity. Step length and velocity significantly increased with levodopa treatment alone or in combination with STN stimulation in both natural and fast gait conditions, and with STN stimulation alone in the fast gait condition. Conversely, SNr stimulation had no significant effect on these measures in either condition. In the natural gait condition, no fall in the centre of gravity occurred as step length was low and active braking was unnecessary. In the fast gait condition, braking was improved with STN or SNr stimulation but not with levodopa treatment, with an increase in the stance leg S muscle activity. These results suggest that anteroposterior (length and velocity) and vertical (braking capacity) gait parameters are controlled by two distinct systems within the basal ganglia circuitry, representing respectively locomotion and balance. The SNr, a major basal ganglia output known to project to pontomesencephalic structures, is postulated as being particularly involved in balance control during gait.
hal-00583628 , version 1 (06-04-2011)
N. Chastan, G. W. M. Westby, J. Yelnik, E. Bardinet, Manh-Cuong Do, et al.. Effects of nigral stimulation on locomotion and postural stability in patients with Parkinson's disease.. Brain - A Journal of Neurology , 2009, 132 (Pt 1), pp.172-84. ⟨10.1093/brain/awn294⟩. ⟨hal-00583628⟩
138 Consultations
0 Téléchargements
