Discrete Cosine Transform, IEEE Transactions on Computers, vol.23, issue.1, pp.90-93, 1974. ,
DOI : 10.1109/T-C.1974.223784
Network Flows, 1993. ,
Information theory and an extension of the maximum likelihood principle, Second International Symposium on Information Theory, pp.267-281, 1973. ,
Exploring large feature spaces with hierarchical multiple kernel learning, Advances in Neural Information Processing Systems (NIPS), 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00319660
Optimization with sparsity-inducing penalties. Foundation and Trends in Machine Learning, pp.1-106, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00613125
The minimum description length principle in coding and modeling, IEEE Transactions on Information Theory, vol.44, issue.6, pp.2743-2760, 1998. ,
DOI : 10.1109/18.720554
A Fast Iterative Shrinkage-Thresholding Algorithm for Linear Inverse Problems, SIAM Journal on Imaging Sciences, vol.2, issue.1, pp.183-202, 2009. ,
DOI : 10.1137/080716542
Efficient RNA isoform identification and quantification from RNA-Seq data with network flows, Bioinformatics, vol.30, issue.17, 2013. ,
DOI : 10.1093/bioinformatics/btu317
URL : https://hal.archives-ouvertes.fr/hal-00803134
Network Optimization: Continuous and Discrete Models, Athena Scientific, 1998. ,
Iterative hard thresholding for compressed sensing, Applied and Computational Harmonic Analysis, vol.27, issue.3, pp.265-274, 2009. ,
DOI : 10.1016/j.acha.2009.04.002
Models of social networks based on social distance attachment, Physical Review E, vol.70, issue.5, p.56122, 2004. ,
DOI : 10.1103/PhysRevE.70.056122
Convex Optimization, 2004. ,
Fast approximate energy minimization via graph cuts, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.23, issue.11, pp.1222-1239, 2001. ,
DOI : 10.1109/34.969114
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.112.6806
A Review of Image Denoising Algorithms, with a New One, Multiscale Modeling & Simulation, vol.4, issue.2, p.490, 2005. ,
DOI : 10.1137/040616024
URL : https://hal.archives-ouvertes.fr/hal-00271141
Sparse signal recovery using Markov random fields, Advances in Neural Information Processing Systems (NIPS), 2008. ,
On Total Variation Minimization and Surface Evolution Using Parametric Maximum Flows, International Journal of Computer Vision, vol.40, issue.9, pp.288-307, 2009. ,
DOI : 10.1007/s11263-009-0238-9
Atomic Decomposition by Basis Pursuit, SIAM Journal on Scientific Computing, vol.20, issue.1, pp.33-61, 1999. ,
DOI : 10.1137/S1064827596304010
Smoothing proximal gradient method for general structured sparse learning, Proceedings of the Twenty-Seven Conference on Uncertainty in Artificial Intelligence (UAI), 2011. ,
Network-based classification of breast cancer metastasis, Molecular Systems Biology, vol.5, issue.140, 2007. ,
DOI : 10.1038/msb4100180
Introduction to Algorithms, 2001. ,
Combinatorial Continuous Maximum Flow, SIAM Journal on Imaging Sciences, vol.4, issue.3, pp.905-930, 2011. ,
DOI : 10.1137/100799186
Elements of Information Theory, 2006. ,
Image Denoising by Sparse 3-D Transform-Domain Collaborative Filtering, IEEE Transactions on Image Processing, vol.16, issue.8, pp.2080-2095, 2007. ,
DOI : 10.1109/TIP.2007.901238
An iterative thresholding algorithm for linear inverse problems with a sparsity constraint, Communications on Pure and Applied Mathematics, vol.58, issue.11, pp.1413-1457, 2004. ,
DOI : 10.1002/cpa.20042
Image Denoising Via Sparse and Redundant Representations Over Learned Dictionaries, IEEE Transactions on Image Processing, vol.15, issue.12, pp.3736-3745, 2006. ,
DOI : 10.1109/TIP.2006.881969
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.109.6477
Variable Selection via Nonconcave Penalized Likelihood and its Oracle Properties, Journal of the American Statistical Association, vol.96, issue.456, pp.1348-1360, 2001. ,
DOI : 10.1198/016214501753382273
Maximal flow through a network, Journal canadien de math??matiques, vol.8, issue.0, pp.399-404, 1956. ,
DOI : 10.4153/CJM-1956-045-5
Community structure in jazz Advances in Complex Systems, pp.565-573, 2003. ,
An Efficient Implementation of a Scaling Minimum-Cost Flow Algorithm, Journal of Algorithms, vol.22, issue.1, pp.1-29, 1997. ,
DOI : 10.1006/jagm.1995.0805
A new approach to the maximum flow problem, Proceedings of the ACM Symposium on Theory of Computing, 1986. ,
Self-similar community structure in a network of human interactions, Physical Review E, vol.68, issue.6, p.65103, 2003. ,
DOI : 10.1103/PhysRevE.68.065103
Complexity and algorithms for nonlinear optimization??problems, Annals of Operations Research, vol.72, issue.3, pp.257-296, 2007. ,
DOI : 10.1007/s10479-007-0172-6
A Path Algorithm for the Fused Lasso Signal Approximator, Journal of Computational and Graphical Statistics, vol.19, issue.4, pp.984-1006, 2010. ,
DOI : 10.1198/jcgs.2010.09208
Learning with structured sparsity, Proceedings of the 26th Annual International Conference on Machine Learning, ICML '09, pp.3371-3412, 2011. ,
DOI : 10.1145/1553374.1553429
A tutorial on MM algorithms. The American Statistician, pp.30-37, 2004. ,
Group lasso with overlap and graph lasso, Proceedings of the 26th Annual International Conference on Machine Learning, ICML '09, 2009. ,
DOI : 10.1145/1553374.1553431
Structured variable selection with sparsity-inducing norms, Journal of Machine Learning Research, vol.12, pp.2777-2824, 2011. ,
URL : https://hal.archives-ouvertes.fr/inria-00377732
Information Theory, Inference, and Learning Algorithms, 2003. ,
Non-local sparse models for image restoration, 2009 IEEE 12th International Conference on Computer Vision, 2009. ,
DOI : 10.1109/ICCV.2009.5459452
Online learning for matrix factorization and sparse coding, Journal of Machine Learning Research, vol.11, pp.19-60, 2010. ,
URL : https://hal.archives-ouvertes.fr/inria-00408716
Convex and network flow optimization for structured sparsity, Journal of Machine Learning Research, vol.12, pp.2649-2689, 2011. ,
URL : https://hal.archives-ouvertes.fr/inria-00584817
Matching pursuits with time-frequency dictionaries, IEEE Transactions on Signal Processing, vol.41, issue.12, pp.3397-3415, 1993. ,
DOI : 10.1109/78.258082
Stability selection, Journal of the Royal Statistical Society: Series B (Statistical Methodology), vol.7, issue.4, pp.417-473, 2010. ,
DOI : 10.1111/j.1467-9868.2010.00740.x
Problem Complexity and Method Efficiency in Optimization, 1983. ,
Gradient methods for minimizing composite objective function, CORE Discussion paper, 2007. ,
Numerical Optimization, 2006. ,
DOI : 10.1007/b98874
Convex relaxations for combinatorial penalties, 2012. ,
On the Lasso and its dual, Journal of Computational and Graphical Statistics, vol.9, issue.2, pp.319-356, 2000. ,
Image denoising using scale mixtures of gaussians in the wavelet domain, IEEE Transactions on Image Processing, vol.12, issue.11, pp.1338-1351, 2003. ,
DOI : 10.1109/TIP.2003.818640
Classification of microarray data using gene networks, BMC Bioinformatics, vol.8, issue.1, p.35, 2007. ,
DOI : 10.1186/1471-2105-8-35
URL : https://hal.archives-ouvertes.fr/hal-00433577
Modeling by shortest data description, Automatica, vol.14, issue.5, pp.465-471, 1978. ,
DOI : 10.1016/0005-1098(78)90005-5
Convergence rates of inexact proximal-gradient methods for convex optimization, Advances in Neural Information Processing Systems (NIPS), 2011. ,
URL : https://hal.archives-ouvertes.fr/inria-00618152
Estimating the Dimension of a Model, The Annals of Statistics, vol.6, issue.2, pp.461-464, 1978. ,
DOI : 10.1214/aos/1176344136
Regression shrinkage and selection via the Lasso, Journal of the Royal Statistical Society: Series B, vol.58, issue.1, pp.267-288, 1996. ,
Simultaneous Variable Selection, Technometrics, vol.47, issue.3, pp.349-363, 2005. ,
DOI : 10.1198/004017005000000139
A Gene-Expression Signature as a Predictor of Survival in Breast Cancer, New England Journal of Medicine, vol.347, issue.25, pp.1999-2009, 2002. ,
DOI : 10.1056/NEJMoa021967
Sparse Reconstruction by Separable Approximation, IEEE Transactions on Signal Processing, vol.57, issue.7, pp.2479-2493, 2009. ,
DOI : 10.1109/TSP.2009.2016892
Model selection and estimation in regression with grouped variables, Journal of the Royal Statistical Society: Series B (Statistical Methodology), vol.58, issue.1, pp.49-67, 2006. ,
DOI : 10.1198/016214502753479356
The composite absolute penalties family for grouped and hierarchical variable selection, The Annals of Statistics, vol.37, issue.6A, pp.3468-3497, 2009. ,
DOI : 10.1214/07-AOS584
Regularization and variable selection via the elastic net, Journal of the Royal Statistical Society: Series B (Statistical Methodology), vol.5, issue.2, pp.301-320, 2005. ,
DOI : 10.1073/pnas.201162998
