New interface
Journal articles
Impact of the Implementation of MPI Point-to-Point Communications on the Performance of Two General Sparse Solvers
Résumé : We examine the send and receive mechanisms of MPI and show how to implement message passing robustly so that performance is not significantly affected by changes to the MPI system. We discuss this within the context of two different parallel algorithms for sparse Gaussian elimination: a multifrontal solver (MUMPS), and a supernodal one (SuperLU). The performance of our initial strategies based on simple MPI point-to-point communication primitives is very sensitive to the MPI system, particularly the way MPI buffers are used. Using nonblocking communication primitives improves the performance and robustness, but at the cost of increased code complexity.
Complete list of metadata
https://hal.inria.fr/hal-00807387
Contributor : Equipe Roma Connect in order to contact the contributor
Submitted on : Wednesday, April 3, 2013 - 2:43:04 PM
Last modification on : Friday, November 18, 2022 - 9:27:39 AM
Links full text
Identifiers
Citation
Patrick Amestoy, Iain S. Duff, Jean-Yves L'Excellent, Xiaoye S. Li. Impact of the Implementation of MPI Point-to-Point Communications on the Performance of Two General Sparse Solvers. Parallel Computing, 2003, 29 (7), pp.833--847. ⟨10.1016/S0167-8191(03)00067-X⟩. ⟨hal-00807387⟩
Share
Metrics
Record views
93
