New interface
Reports (Research report)
Scheduling strategies for mixed data and task parallelism on heterogeneous processor grids
Olivier Beaumont 1, 2 Arnaud Legrand 3, 4 Yves Robert 3, 4
2 CEPAGE - Algorithmics for computationally intensive applications over wide scale distributed platforms
Université Sciences et Technologies - Bordeaux 1, Inria Bordeaux - Sud-Ouest, École Nationale Supérieure d'Électronique, Informatique et Radiocommunications de Bordeaux (ENSEIRB), CNRS - Centre National de la Recherche Scientifique : UMR5800
3 REMAP - Regularity and massive parallel computing
Inria Grenoble - Rhône-Alpes, LIP - Laboratoire de l'Informatique du Parallélisme
Abstract : In this paper, we consider the execution of a complex application on a heterogeneous grid computing platform. The complex application consists of a suite of identical, independent problems to be solved. In turn, each problem consists of a set of tasks. There are dependences (precedence constraints) between these tasks. A typical example is the repeated execution of the same algorithm on several distinct data samples. We use a non-oriented graph to model the grid platform, where resources have different speeds of computation and communication. We show how to determine the optimal steady-state scheduling strategy for each processor (the fraction of time spent computing and the fraction of time spent communicating with each neighbor). This result holds for a quite general framework, allowing for cycles and multiple paths in the platform graph.
Complete list of metadata
https://hal.inria.fr/hal-00807405
Contributor : Equipe Roma Connect in order to contact the contributor
Submitted on : Wednesday, April 3, 2013 - 2:53:46 PM
Last modification on : Wednesday, October 26, 2022 - 8:16:23 AM
Identifiers
  • HAL Id : hal-00807405, version 1
Collections
Citation
Olivier Beaumont, Arnaud Legrand, Yves Robert. Scheduling strategies for mixed data and task parallelism on heterogeneous processor grids. [Research Report] 2002-20, 2002. ⟨hal-00807405⟩
Share
Metrics
Record views
108
