On preserving dissipativity properties of linear complementarity dynamical systems with the $θ$-method
In this work we study the following problem: given a numerical method (an extended $θ$−method named the ($θ,γ$)-method), find the class of dissipative linear complementarity systems such that their discrete-time counterpart is still dissipative, with the same storage (energy) function, supply rate (reciprocal variables), and dissipation function. Systems with continuous solutions, and with state jumps are studied. The notion of numerical dissipation is given a rigorous meaning.
